Author Topic: Chrome Touchup -  (Read 1763 times)
Chrome Touchup -
« on: August 29, 2022, 07:02:30 PM »
I found this on Amazon and it works good (so far). I used it to touch up some worn chrome on the plastic trim rings from a 66 Rally Pak.
https://www.amazon.com/Molotow-Liquid-Chrome-Marker-Large/dp/B077SFF28H/ref=sr_1_9?crid=3999RIY9ADSVJ&keywords=molotow+liquid+chrome&qid=1661809614&sprefix=molotow+%2Caps%2C197&sr=8-9
There are other size tips, this one is 5mm. It uses a pump action on the tip to get the chrome to flow, then it went on nicely.
The "recommendation" is that this marker is something to consider for chrome touch up. My next "chrome touch up" is the trim on a 65 radio bezel. I would not use this on an exterior surface, but you never know.
Re: Chrome Touchup -
« Reply #1 on: August 29, 2022, 07:09:57 PM »
cheap enough to experiment with.........pics would be nice too.
« Reply #2 on: August 29, 2022, 07:47:09 PM »
The edge of the 2 1/2 inch diameter ring that I touched up is 0.075 inch thick. Pictures are "difficult".
« Reply #3 on: August 29, 2022, 08:22:48 PM »
The "show and tell" chrome is drying on a couple of black (for contrast) surfaces. It was applied under the influence of a Brandy Manhattan. Pictures to follow (after dinner, a T-bone).
« Reply #4 on: August 30, 2022, 04:55:01 PM »
After several attempts to make a "show and tell" picture on different surfaces with the "Chrome Pen", I went with the actual plastic trim ring that goes on top of the Rally Pac gauges, inside the outer ring housing.
The red arrow on the right points to the ring, the only part seen from the outside. The red arrow on the left show what was not "chromed", a "before" the treatment, and that is not visible when assembled.
What was also learned are: the surface must be clean and dry; a rough surface will fill up with the ink, so do those first, let the piece dry, and add a second coat (or more); smooth out the ink as you apply it. The ink drys quickly so let it. Don't "test" - (aka push your luck) - it. I don't know how this ink will wear over time.
Offline Daven
« Reply #5 on: August 31, 2022, 01:06:13 AM »
I just ordered two pens from Amazon.  I can't wait to try it out!  Thanks Jim.
Offline upsetter
« Reply #6 on: December 14, 2022, 10:50:08 AM »
I wonder how it would do on the "pot metal" piece on the vent window pivot?
7T02S173XXX  GT  built: 12/28/66
« Reply #7 on: December 14, 2022, 11:35:49 AM »
That piece is brass, not pot metal.
With a Dremel you can get off the flaking chrome and get it sanded and buffed up real well.
After that i taped off the area and bright zinc plated it at home.
We shall see how long that works.
[I did this on my modified car]
« Reply #8 on: December 14, 2022, 01:26:36 PM »
I tried it on a worn radio knob - twice. It works "sometimes". My second attempt included a quick wipe which got my first attempt hidden, then I did a coverup. "You" can't tell, but I can. It's trial and error. Also, it's a "touch up", not a complete re-chrome. Don't bother with exterior surfaces, ones that have a high wear potential, or ones with a dark surface.
Offline upsetter
« Reply #9 on: December 16, 2022, 11:52:09 PM »
Thank you. I have some spare pieces to try it out on.
Offline HDAshmore
« Reply #10 on: December 18, 2022, 10:13:35 AM »
FWIW you can find the chrome pens mentioned above at Hobby Lobby in the sharpie and pencil section.  At least in my area.  They had several different size pens.
Dan in Kansas
