Author Topic: The Remove post button is gone!  (Read 1578 times)
« on: August 24, 2022, 02:44:41 PM »
It seems that Richard and I have the same issue -- we can no longer delete/remove a post.
Why?
« Last Edit: August 24, 2022, 03:19:21 PM by Bossbill »
Re: The delete post button is gone!
« Reply #1 on: August 24, 2022, 02:46:13 PM »
are you referring to the 'remove post' tab? i have it on my screen.
« Reply #2 on: August 24, 2022, 03:01:38 PM »
Since it's not there I don't recall what it was called!
It used to be next to the Modify button.
Have I been breathing too many paint fumes?
« Reply #3 on: August 24, 2022, 03:13:04 PM »
Improvise. Modify your **** post by removing your **** and replacing it with "Deleted". The main reason is that "replies" are (usually) not yours, and you can't delete them.
It's the simple things in life, ain't it.
« Reply #4 on: August 24, 2022, 03:18:34 PM »
Huh?
I'm not trying to remove the posts of others. Just mine.
I used to be able to do that.
« Reply #5 on: August 24, 2022, 04:05:47 PM »
Huh?
The reply to your post is attached to your post, the one you want to delete. If you remove yours, the reply has nowhere to go.
Re: The Remove post button is gone!
« Reply #6 on: August 24, 2022, 04:56:39 PM »
Does it work now for you?
« Reply #7 on: August 24, 2022, 05:42:47 PM »
Yes, thank you.
I put it here rather than a PM is because it affected more than just me.
For those who think I inhaled a now legal substance here is the new screen shot.
Compare far right to before.
« Last Edit: August 24, 2022, 05:45:00 PM by Bossbill »
« Reply #8 on: August 24, 2022, 11:54:40 PM »
Smog?
Years ago, on a forum I contributed to, the removal/deletion of a post in a thread was as I said, more of an erasure than a removal. Better software today.
« Reply #9 on: August 25, 2022, 07:58:51 AM »
Why?
It is working now. Thanks. I also just updated my device software. I figured that fixed it but apparently others noticed this too. In any event, I was now able to clean up my mistakes in those posts.
« Reply #10 on: August 25, 2022, 11:50:40 AM »
Smog?
When I update my long, multi-item For Sale ad instead of adding multiple posts with "Bump" or similar I add a new post saying "Added [item]" and then remove previous updates.
It keeps things clean and simple. Not that there's anything clean or simple with most of my posts!
« Reply #11 on: August 25, 2022, 01:19:46 PM »
I use the items for sale lists to determine a price for what I need to sell, so by you deleting them, you defeat the historical purpose of items for sale prices.
(Shame on you. No beer today, until at least 4:30PM.)
« Reply #12 on: August 25, 2022, 02:42:39 PM »
Most or few delete them and this is why I try and lock them once something is sold
« Reply #13 on: August 25, 2022, 05:09:21 PM »
What I delete are the last updates that say things "List updated to add radiator".
I then add radiator to the list (post #1).
Later, if I add another item, I add another post like "List update to add alternator" and then delete the previous radiator post. The radiator will still be in post #1 as will the newly added radiator.
I rarely bother with Bump, but if I do I delete the first bump and add a new bump.
« Last Edit: August 25, 2022, 05:11:42 PM by Bossbill »
