Author Topic: Looking for under sill wiring clips  (Read 745 times)
« on: August 21, 2022, 12:09:25 AM »
Looking for original used wiring clips that are typically found on 65-68 (maybe later), under sill plate to hold up tail light wiring, power top wiring...
Let me know what you have.  Painted originals are fine, just so long as they can still be used.
Re: Looking for under sill wiring clips
« Reply #1 on: August 21, 2022, 12:41:22 AM »
So that's what those are.
« Reply #2 on: August 21, 2022, 09:38:36 AM »
I have seen them on the 65-66 cars but not on 67-68s
« Reply #3 on: August 21, 2022, 11:27:33 AM »
377864-S (GG-230)  I can get some in a few weeks from the junkyard if you don't find any before then.
The MPC lists them for 65-68 convertible, but I did not find them in neither the 67 nor 68 assembly manuals.
Also used on:
62/63 Fairlane, 63/64 Falcon - wiring to rocker panel
63 Fairlane, 63/64 Falcon wagon, wiring to rocker panel
63 Falcon convertible, wiring to rocker panel
64 Falcon - wiring to cross member
Did not check Mercury models, but usually there is a direct correlation to the equivalent models.
« Last Edit: August 21, 2022, 11:34:35 AM by 67gta289 »
Offline Whiteykr
« Reply #4 on: August 22, 2022, 07:11:56 PM »
Charles,
I have these and will send you a PM tonight.
Brad
Offline Flade
« Reply #5 on: September 15, 2022, 02:11:00 AM »
Brad,  if you have any extra I need 2 of the clips as well
Thanks. David
68 Convertible, 289 C4, SJ May 68 build date
Offline Whiteykr
« Reply #6 on: September 16, 2022, 09:47:11 PM »
David,
I will PM you tonight. I have them
Brad
