Author Topic: Junkyard guessing game  (Read 3181 times)
Offline kcodecoupe
Re: Junkyard guessing game
« Reply #15 on: August 13, 2022, 09:33:18 PM »
With the  R & L dual exhaust floor pan support plates and hanger brackets . its a 66 GT possible  K code if it has the original 9 nch rear diff axel still under it .
Offline aaatp
« Reply #16 on: August 13, 2022, 09:34:50 PM »
65 door window regulator handle.
« Reply #17 on: August 13, 2022, 10:10:58 PM »
The VIN does start with a 5.  The warranty plate date code is 09J.  Would that be Sept 9 of 65 or 66?  Dearborn assembled.
« Reply #18 on: August 13, 2022, 10:17:11 PM »
Sept 64
« Reply #19 on: August 13, 2022, 10:22:42 PM »
Sept 64
When were the last of the squared corner sill plates used?
« Reply #20 on: August 13, 2022, 10:35:49 PM »
Guess your asking specifically about Dearborn and for convertible since they were different from the other two body styles. We've not posted that info in that Running Changes thread yet but will look unless someone has already done the work and posts it before I respond. Looks like I've already graphed some findings but would be good, given how long its been since i did the collection, to go through it again for new examples
A a comment about the dual exhaust mounting brackets and their orientation even that would narrow down the production period. Will leave that to others so I don't hog the responses. Maybe I should have recused myself also to let others have more time and involvement
« Last Edit: August 13, 2022, 10:40:29 PM by J_Speegle »
Offline kcodecoupe
« Reply #21 on: August 14, 2022, 08:28:15 AM »
I guess with a 5 in the vin it rules it out as a 66 and GT  . a p[icture of the firewall would help .
« Reply #22 on: August 14, 2022, 08:44:21 AM »
firewall picture
« Reply #23 on: August 14, 2022, 07:42:48 PM »
Offline kcodecoupe
« Reply #24 on: August 15, 2022, 07:42:15 AM »
firewall picture
Its hard to see from the angle of the photo and the weeds, is there a hole for a manual choke cable in the firewall.
« Reply #25 on: August 15, 2022, 07:50:39 AM »
This is the only other angle I have of this area
« Reply #26 on: August 15, 2022, 12:31:42 PM »
Since the discussion died down, probably time to help answer a few questions and speculation
Offline kcodecoupe
« Reply #27 on: October 10, 2022, 09:55:18 PM »
Well its  a 289 K code hipo per the vin plate, also see square corner sill plates ,with a sept 64 build it could be a generator vs an alternator charging system. cant tell if that is a choke cable near the firewall or a weed stalk, those square corner sill plates might be worth something.
