Author Topic: 428 CJ Radiator hoses  (Read 519 times)
Offline Daven
« on: August 04, 2022, 02:16:32 AM »
Do these radiator hoses look original?  1969 R-code San Jose September 68 build.  Auto with AC
« Last Edit: August 04, 2022, 03:43:00 PM by J_Speegle »
Offline Scode67FB
Re: Radiator hoses
« Reply #1 on: August 04, 2022, 05:16:09 AM »
The number on it looks like "D0ZE" so that wouldn't be original for a 69.
Offline Daven
Re: Radiator hoses
« Reply #2 on: August 04, 2022, 03:28:08 PM »
With new stamping, replated clamps and staples it would be as good as new.
Offline preaction
Re: 428 CJ Radiator hoses
« Reply #3 on: August 04, 2022, 03:45:22 PM »
Will it be as durable as new ?
« Reply #4 on: August 04, 2022, 04:01:57 PM »
As New? Likely no but usable? Maybe. Test for flexibility, inner or outer cracking. Separation and any damage after a good cleaning. Then carry a set of new ones if your driving the car or only use these for shows.
Offline Daven
« Reply #5 on: August 04, 2022, 04:27:42 PM »
I don't plan to ever drive it.  At times when I look at the number it looks like a "C" not a "D."  I take it that one is the lower hose?  What is the proper stamp number?  I have a few at the shop to check out, but I assume the less curvy one is the upper?
« Reply #6 on: August 04, 2022, 04:56:20 PM »
Just compare what you have to the upper ones shown on cars int he unrestored picture threads of 69 CJs and the one that does not match is likely the lower though I guess you can look up the shape of the lowers just to make sure there was not redesign in 70 from the 69 design
« Reply #7 on: August 04, 2022, 05:15:12 PM »
Fairlane and Torino are different . Upper is taller . Lower is longer in one of the directions.
