Author Topic: Turn signal switch wiring part numbers  (Read 558 times)
Offline Buzz489
« on: July 31, 2022, 05:21:48 PM »
I'm trying to figure out if my mustang has it's original turn signal switch wiring. I have a July SJ Mach One. When I took apart my Steering column I found turn signal switch wiring C9AA 13B302-F and appears it to be original. In another 69 mustang steering column (no other info on this column) I found C9ZA 13B302-G. Can a C9AA part number be original to my Mustang?
Re: Turn signal switch wiring part numbers
« Reply #1 on: August 03, 2022, 06:43:56 PM »
Remember and consider that the number your seeing on the wire loom is not the part number but the engineering number. Often two different numbers as this example shows. MPCS will somethings show both but for ordering a part for replacement they are going to use the number on the box or package - the part number
Offline Buzz489
« Reply #2 on: August 03, 2022, 10:43:47 PM »
Thank you Mr Speegle. My question or concern comes from my original steering column and a spare I picked up years ago. I believe my steering column and components are original and thought nothing of the C9AA until I took apart my spare and found the C9ZA. I plan to have the column rebuilt and want to know which wiring to reassemble it with.
« Reply #3 on: August 04, 2022, 05:03:17 PM »
Looking at a Dec 1969 MPC they list the engineering numbers also and apparently there were a number of small changes to the loom  through the production years identified by
C9ZA-13A302- C D E H J  and L
Part number C9ZZ-13441-C for the fixed column applications
Can't example the C9AA printing. Might be a misprint
Offline 9F94M567042
« Reply #4 on: August 04, 2022, 07:07:06 PM »
This may or may not help but this is what I found in the May 1975 MPC.
Fixed Column
ID Marking of C9AA-13B302-A,B,C,D,E & F
Part Number is C9AZ-13341-B
Tilt Column
ID Marking of C9ZA-13B302-B,F & K
Part Number is C8SZ-13341-B
Comments welcome
« Reply #5 on: August 04, 2022, 07:48:53 PM »
Fixed Column
Maybe the corrected the mistake in the part ID on the period MPC in later versions
