Author Topic: tough paint removal problem  (Read 831 times)
Offline rtate
« on: July 22, 2022, 11:28:54 AM »
I had a friend media blast my hood hinges and he couldn't get all the paint off the parts.
Said he used an "industrial stripper"
What do you suggest I use to get this stubborn paint off ?
December 10/64 Dearborn K code, Convertible
Silver Smoke Gray
Re: tough paint removal problem
« Reply #1 on: July 22, 2022, 12:56:00 PM »
Try: acetone; Krud Kutter (available at home depot); a generic paint remover (also Home Depot); used carburetor cleaner (Berryman B-12 - I use it to soak bolts with a lot of paint on them); a different "media" - I prefer glass beads.
« Reply #2 on: July 22, 2022, 02:12:24 PM »
It might be a 2K paint -- which is much harder to remove than the 1K used originally.
I would use a cold tank dip (if available) or use a more aggressive media than glass bead.
Some people are afraid to turn up the glass ball media, but it will cut better at 100psi than the usual 35-40. It will also break down faster.
If using an aluminum oxide media you can follow it with the glass ball to get a better finish.
Most people don't understand that the pressure media is like sandpaper and you can go from a course grit to a finer grit (in stages, too). You will also lose details in the process, just like sandpaper.
« Reply #3 on: July 22, 2022, 02:28:02 PM »
Can soak the parts in urethane reducer (kind of expensive to do that).  Or, find a wheel shop locally that does powder coating, they might be willing to dip them in the stripper they use for wheels.  There's a Benco product I have used, some really nasty stuff, but don't think they sell to J.Q. Public anymore.
Offline 69bossnut
    • DSD Restorations LLC
« Reply #4 on: August 25, 2022, 12:24:06 PM »
Sometimes a local radiator shop has dip tank that will do it for you as well.
DAVID DAVIS
DSD RESTORATIONS LLC
5075 E. COUNTY RD. 126
BLYTHEVILLE, AR. 72315
870-780-4999
dsdresto@gmail.com
www.dsdrestoration.com
