Author Topic: Painting the 69 428CJ engine, pics added  (Read 605 times)
Offline 69supercj
« on: July 21, 2022, 03:42:16 PM »
Trying to get the motor ready for primer and I'm having trouble with it flashing with rust after I clean it. I've been using mineral spirits with a brass bristle brush followed by Brake kleen and its flashing mostly around the exhaust flanges where it had developed some light surface rust. What can I use to stop the flash and that can be primed over without removing? Metal prep? Evaporust? ???? As a side note, our humidity is pretty low right now but its 102 degrees. Its supposed to be in the low to mid 70's tomorrow morning which is when I  plan on spraying the primer.
« Last Edit: July 22, 2022, 05:05:14 PM by J_Speegle »
Re: Painting the engine
« Reply #1 on: July 21, 2022, 05:03:07 PM »
Try a wire brush to remove the "rust", then paint it immediately. Forget the primer.
« Reply #2 on: July 21, 2022, 05:30:13 PM »
+1 .You don't need to use the primer. The factory did not use it ether.
« Reply #3 on: July 21, 2022, 07:48:00 PM »
Use a high temperature Ford engine blue paint, the daker version.
« Reply #4 on: July 21, 2022, 07:52:38 PM »
+/ :)  Primer will just hide more of the details and make the final product look more like it was dipped in paint/plastic. Not the end look  your looking for
Offline 69supercj
Re: Painting the engine, pics added
« Reply #5 on: July 21, 2022, 09:48:43 PM »
Needing to know if the stud in the first pic gets painted as well as the elbow in the second pic. Thanks!
Offline rockhouse66
« Reply #6 on: July 21, 2022, 10:22:25 PM »
Yes to both - stud and elbow.  Tape off the end of the elbow for the hose would be my approach.
You didn't ask, but the other heater hose fitting - the one that screws into the water pump - was not painted.
A lot of detailing info here;  https://secureservercdn.net/198.71.233.167/xnm.126.myftpupload.com/wp-content/uploads/2021/09/cobrajet_engine_detail_v1.3.pdf
« Last Edit: July 22, 2022, 01:58:04 PM by rockhouse66 »
'66 GT FB
« Reply #7 on: July 21, 2022, 11:16:38 PM »
Ospho is a good option for cleaning/etching the bare metal.  Make sure it's compatible with the topcoat.
