Author Topic: OEM Boss 351 main bearings  (Read 5052 times)
Offline c9zx
« on: July 20, 2022, 09:03:13 PM »
Can anyone confirm, or refute, that Boss 351 Engines came with full groove main bearings? Thanks, Chuck
Thanks, Chuck
1969 G code Cougar Eliminator
CSX 7031
Offline c9zx
Re: OEM Boss 351 main bearings
« Reply #1 on: July 22, 2022, 07:29:33 PM »
Bump. Can anyone answer this question? I ask because I'm looking at crank oil hole "timing" to the rod bearings. Thanks, Chuck
Thanks, Chuck
CSX 7031
« Reply #2 on: July 22, 2022, 07:58:22 PM »
Don't think I got anything to confirm the design. Might be a quick and easy question for the Boss 351 guys over on the Boss Registry forum
https://www.boss302.com/smf/index.php?board=13.0
Offline c9zx
« Reply #3 on: July 23, 2022, 09:22:51 AM »
Jeff, I have posted the same question there as well. So far nothing. Thanks, Chuck
Thanks, Chuck
CSX 7031
Offline c9zx
« Reply #4 on: July 24, 2022, 06:16:11 PM »
This information comes from a friend who worked in Ford Parts Department for decades. It answers my question comprehensively. Others my find it useful in the future. Not using full groove mains on 351C causes rod bearing failure when used with a stock crank. The "timing" of the oil holes were not properly indexed to oil the rods when they needed it the most.
Thanks, Chuck
CSX 7031
« Reply #5 on: July 24, 2022, 11:12:06 PM »
the file type is not typical for most computers.  Can you convert it to PDF or double-check that it is truly .pages file type?
« Reply #6 on: July 24, 2022, 11:58:28 PM »
Try this https://www.freeconvert.com/pages-to-word
No guarantees, I did not try it myself.
« Reply #7 on: July 25, 2022, 12:09:26 AM »
For Windows 10 -
Step 1: Down load the .pages file to your computer.
Step 2: Open the conversion program shown in my previous post. It will appear in the "downloads" directory for conversion
Step 3: Convert using YOUR device to Word:
Step 4: It should show up in "downloads" directory.
This above assumes you are using a computer, not a cell phone.
« Reply #8 on: July 25, 2022, 01:31:47 PM »
Here is the same document in a more common PDF file.
« Reply #9 on: July 25, 2022, 03:59:50 PM »
Well, if you're going to be that way about it, here's a .docx of the file.
« Reply #10 on: July 25, 2022, 06:25:25 PM »
Kind of expected it was going to take someone with a set of Ford bearings or some obscure engineering drawing with the details
