Author Topic: C9AF-N carb kit  (Read 368 times)
Offline 69supercj
C9AF-N carb kit
« on: July 20, 2022, 12:35:13 PM »
Whats the recommended kit for these?
Re: C9AF-N carb kit
« Reply #1 on: July 20, 2022, 02:59:29 PM »
There's not a kit to buy - you need to buy the individual parts from Holley. A Trick Kit is a nice start, then you will need the accelerator pump diaphragm. For CJ carbs I keep all the parts in multiples because I have to often work on them.
Re: C9AF-N carb kit
« Reply #2 on: July 20, 2022, 03:08:04 PM »
BTW the Trick Kit does not contain any needle / seat assemblies so you will need two of those, I prefer the Viton tipped ones. There are also no floats in the Trick Kit, often you will open the carb and find a nitrophyl (molded plastic) float. I like the brass ones better.
Offline 69supercj
Re: C9AF-N carb kit
« Reply #3 on: July 20, 2022, 04:45:04 PM »
Well crap. I just called Holley and they said I needed the 3-1184 and also the 135-3 secondary diaphragm kit so thats what I ordered from Summit. Guess we'll see what else I'm gonna need.
Re: C9AF-N carb kit
« Reply #4 on: July 20, 2022, 06:32:34 PM »
There are Borg Warner kits and others that don't have Holley quality or performance. Stay away from any non - Holley parts. Note that Holley owns Moroso and I think Quick Fuel - check the holley.com website.
I normally get the part numbers on the Holley site and then buy from Summit - they are cheaper. Just put hly in front of the part number.
Offline hopey
Re: C9AF-N carb kit
« Reply #5 on: July 20, 2022, 10:55:21 PM »
Drew at Air Fuel Spark sells kits as well as does restorations.
https://www.afscarbs.com/product-page/boss-cobrajet-rebuild-kit
1970 BOSS 302
Built 11/15/69 Dearborn
