Jeff, if I replace with the updated version how would that be judged in concours driven?Pete
Pretty simple IMHO If it's visually different then you should expect a deduction orat minimum a comment if your lucky. No reason you getting full points when its not correct and possibly someone else in the class has the correct version if the intent is to restore the car. Driven only means that there are exceptions in the rules for certain things that are spelled out if you asking about MCA
