Author Topic: Clear glass car got tinted glass windshield ?  (Read 4868 times)
« on: July 06, 2022, 08:14:54 PM »
Our 3-19-68 GT 350 did not have the optional tinted glass. It has a correct date coded Sun X tinted windshield which I think is original. Would that been how it should have come or should it have a clear windshield with the upper tint band?
Re: Clear glass car got tinted glass windshield ?
« Reply #1 on: July 06, 2022, 09:08:40 PM »
It's tough to do, but you can you snap a pic?
I'm wondering if it says SUN VISOR or SUN VISOR and SUN-X on two lines.
See:
https://www.concoursmustang.com/forum/index.php?topic=23597.msg165188#msg165188
« Reply #2 on: July 06, 2022, 09:24:54 PM »
Here is how it reads
      Carlite
  D sun visor R
  5C sun X ASA
     FM-M03
On the build sheet the box for tinted glass is open. The side glass is clear BTW this is a convertible.
« Reply #3 on: July 06, 2022, 10:00:03 PM »
SUN VISOR says you have the band at the top.
SUN-X says it's tinted. Just like the tinted windshield in the referenced post and the side windows in there.
If you place a piece of white paper on the other side of the glass is it green at all?
By the way, from what little data I have or have seen, 68 started changing the "FM-M" suffix numbers which will also indicate if the window is tinted or not.
M07 is on my referenced window and M03 is on yours.
I don't have the codes to de-reference that and none of the online or Marcus' article reference that either.
« Reply #4 on: July 06, 2022, 10:11:10 PM »
What does the Marti Report say?
« Reply #5 on: July 06, 2022, 10:43:04 PM »
The Marti Report does not mention tinted glass and as said above the build sheet does not have the tinted glass box checked.
« Reply #6 on: July 06, 2022, 10:44:16 PM »
      Carlite
  D sun visor R
==>  5C sun X ASA
     FM-M03
I got so caught up n the sun-x part I didn't catch the date. These are very hard to read. Are you sure it's 5C and not 8C and if 8C makes sense to your car's date?
« Reply #7 on: July 06, 2022, 10:49:44 PM »
Well a tinted windshield is a great thing. I think the date code tells you it's not original. The Marti Report is confirmation.
« Last Edit: July 07, 2022, 10:21:04 AM by RoyceP »
« Reply #8 on: July 07, 2022, 12:47:03 AM »
It is a very light stamp. I will check it again tomorrow. Thanks for the help.
« Reply #9 on: July 07, 2022, 02:33:46 PM »
Ok I looked at it again and it is defiantly 5C. I am a bit embarrassed to say at first, I misread this 5C as the 5th of March.  You guys are right the windshield should be clear with the tinted sun visor. I am grateful to get this sorted out because I am ordering a new windshield and want it to be correct.
« Reply #10 on: July 07, 2022, 05:55:06 PM »
Marty: Normally, 68 Shelby's had all clear glass.  I had this wrong on my car and corrected it during the re-restoration.
« Reply #11 on: July 07, 2022, 08:59:14 PM »
Charles thanks for the tip. I got to thinking about it this afternoon and wondered how you could tell if windshield had the tint band or was all clear. I check our unrestored 68 HCS and it is all clear.  You would not happen to remember what your car's date code was? Our cars build dates were close if I remember correctly.
« Reply #12 on: July 07, 2022, 10:00:12 PM »
My car was a late April build.  Pete D. probably has enough info/build-sheets to help answer the question.
« Reply #13 on: July 07, 2022, 10:40:47 PM »
Just got an all clear reproduction from ECS. Ahead of schedule and perfect. Any date code you want.
« Reply #14 on: July 08, 2022, 12:20:34 AM »
I'd love to see the Carlite logo on the ECS windshield.
