70 fuel tank mounting bolts issue,10-21-69 N-J car
Putting fuel tank in, There are 11 bolts hold tank in. The 4 bolts across the back of tank tighten into the body prefect, the other 7 the holes in body already to big to tighten factory bolts, trying to find a remady.. and not get docked in judging. Thought about Putting ford style cage nuts on 7 screws , kinda like the hood scoop ring nuts. if I would of had a clue I would of welded up holes and resized them, should of would of?. Cars in final assy mode now fresh paint and all. When i tore the car down the P O had just put a new fuel tank in and had put the bolts in and let the caulking or dumdum hold bolts, well thats not kool the tank needs to be bolted in as for the strenth of the rear trunk area of the car. So thought about putting the7 bolts in from the bottom and the nuts on the top hidden by trunk sound pads and trunk mat(Any ideas) Thanks Greg
