Author Topic: engine block drains  (Read 596 times)
Offline cob428
engine block drains
« on: June 23, 2022, 12:16:05 AM »
ok have a weird question, engine out both block drain plugs came out fairly easy. The drain hole on the passenger side is, lets say,  a dummy hole goes to nothing, blocked off. The drivers side opens into the rest of the water jacket, you can shine a flashlight into the freeze plug hole and see the light through the block drain hole, not on the other side.
Any thoughts or help we be greatly appreciated.
Pete
Concourse Wantabe
69 GT 500 Built Dearborn 06/69
A/C, Auto,
69 Mach 1 Metuchen 11/68
A/C, Auto 351 W
2009 Supersnake
Offline ninedrvr
Re: engine block drains
« Reply #1 on: June 23, 2022, 09:44:31 AM »
I would guess the one drain is simply blocked. My 428 had about 1 1/2 inches of debris at the bottom of the coolant passages. What worked best was a long thin screwdriver and a ton of patience. I used the screwdriver in every hole I could get it into to dislodge the debris. I got most of it out before I sent it to the machine shop. Their bake and media tumble routine got the rest.
