Author Topic: Oil sending unit  (Read 1043 times)
Offline cob428
Oil sending unit
« on: June 19, 2022, 12:17:04 PM »
Trying to determine if this is the original oil pressure sending unit for June built 1969 GT500? In all the searches I find units without the black cover?
Concourse Wantabe
69 GT 500 Built Dearborn 06/69
A/C, Auto,
69 Mach 1 Metuchen 11/68
A/C, Auto 351 W
2009 Supersnake
Re: Oil sending unit
« Reply #1 on: June 19, 2022, 12:23:42 PM »
Originals are a gold finish and are 1/4" NPT on the end. The one in your picture has an adapter. Many things wrong with that compared to the original part.
« Reply #2 on: June 19, 2022, 02:08:24 PM »
That is a Stewart Warner sender like what is used with 68 Shelby . The 69/70 Shelby used a Ford sender that is bell shaped ,zink dichromate and the assemblyline units are identified with the FoMoCo trademark in block letters inside a rectangle not a oval.
« Reply #3 on: June 19, 2022, 07:54:12 PM »
Bill at Mansfield Mustang had a few NOS oil senders for your car left a few weeks ago. If I were you I would call him tomorrow.
Offline cob428
« Reply #4 on: June 19, 2022, 08:16:13 PM »
Do the tachometer cars and non tach cars take the same sending unit? Bulb type correct?
Concourse Wantabe
A/C, Auto,
A/C, Auto 351 W
2009 Supersnake
« Reply #5 on: June 19, 2022, 11:31:37 PM »
If you have an oil gage you need the large sender. If you have an idiot light you need the small one with the green plastic.
Offline cob428
« Reply #6 on: June 20, 2022, 02:40:16 PM »
Royce, I talked to Bill and he is not sure the bell type sending unit will work with the Shelby. He does have a couple of them C9ZZ-9278-A but wasn't sure it would be correct. Any input on this?
Pete
Concourse Wantabe
A/C, Auto,
A/C, Auto 351 W
2009 Supersnake
« Reply #7 on: June 20, 2022, 08:58:16 PM »
Pete
If you have a tach then you need the sender for an idiot light:
« Reply #8 on: June 21, 2022, 12:22:49 AM »
All 69/70 Shelby's have a oil pressure gauge and use the bell type. I am not sure why a tach car would need one sender over the other since the tach has nothing to do with oil pressure.   The sender has to do with if a oil pressure gauge is present which shows a range of pressure (bell shape) vs. no gauge and instead a idiot light which activates (button type) when at minimum oil pressure .
« Reply #9 on: June 21, 2022, 12:51:00 PM »
Bob I forgot this was a Shelby. If it were a normal Mustang then there would be no place for an oil pressure gage with a tach.
Sounds like Bill has you covered if you act fast enough.
« Reply #10 on: June 21, 2022, 04:28:00 PM »
This is kind of deja vu . Wasn't it me making a similar mistake of not looking at the category in regards to a Mach I a few days ago and you catching it?  ;D    It's all good.
Offline cob428
« Reply #11 on: June 21, 2022, 06:55:13 PM »
I appreciate all the help all of you have been giving me. Everything has worked out fine Thank you
Concourse Wantabe
A/C, Auto,
A/C, Auto 351 W
2009 Supersnake
