Author Topic: OK, what is it?  (Read 1135 times)
OK, what is it?
« on: June 12, 2022, 03:12:32 PM »
You guys like to strut your stuff. Is this clip for a Mustang? Specifically a 67?
Re: OK, what is it?
« Reply #1 on: June 12, 2022, 03:59:02 PM »
It's the retainer for a rubber finger from an automatic chicken plucker.
As far as I can tell, this "clip" does not appear in the"Ford Standard and Utility Parts Catalog, January 1969" book.
« Last Edit: June 12, 2022, 04:05:09 PM by jwc66k »
Re: OK, what is it?
« Reply #2 on: June 12, 2022, 04:11:02 PM »
I am not familiar with all models of automatic chicken pluckers but I am certain it retained the fuel line at the rim of the gas tank flange on a 67-68 Mustang. It clips into a small hole there.
You have to be careful to not say chicken plucker too fast, it might sound like something else. ;)
Re: OK, what is it?
« Reply #3 on: June 12, 2022, 04:49:08 PM »
Thanks, Marty.
It is indeed a fuel line clip as shown very badly on page 42 of the Chassis Assembly Manual.
Clip 377119-S32 (Olive drab or baked black).
Into the plating pile it goes.
« Last Edit: June 12, 2022, 04:52:11 PM by Bossbill »
Offline Kyle Zammit
Re: OK, what is it?
« Reply #4 on: June 12, 2022, 05:12:28 PM »
Bill,
That clip is like for the 67 Mustang heater switch that clips to heater controler.
Here is a picture:
Kyle.
Re: OK, what is it?
« Reply #5 on: June 12, 2022, 05:16:17 PM »
Thanks, Marty.
It is found on 67-70 as a fuel line clip . Olive drab typically on 67 and some 68's and black oxide/baked black? on later 68-70.
Offline Coralsnake
Re: OK, what is it?
« Reply #6 on: June 12, 2022, 05:38:15 PM »
Looks too small for the fuel line clip. The heater control panel guess looks more appropriate
Re: OK, what is it?
« Reply #7 on: June 12, 2022, 06:01:34 PM »
Bill,
Kyle.
Kyle -- Yep, there too. It's identical. Good eye.
Coralsnake -- I got out the correct size 5/16 drill bit and this would certainly hold the gas line very snugly. As for the larger 68, I don't want to stretch this clip out any further.
It fits into the fuel tank area hole very nicely.
Re: OK, what is it?
« Reply #8 on: June 12, 2022, 07:43:18 PM »
If in fact, the clip is 377119-S32, it's also used on 64 thru 66 Mustangs for the same fuel line retaining.
Clip, 377119-S2 (note, it's -S2, and is not serviced), is shown in the illustrated section of "Ford Car Parts" (aka MPC) as used in 67 and 68 heater control power cable. I will add it to the hardware spreadsheets (after I finish a couple of other projects).
Available AMK.
« Last Edit: June 12, 2022, 08:03:23 PM by jwc66k »
