Author Topic: GT350 PCV Hose  (Read 740 times)
Offline S412gofast
GT350 PCV Hose
« on: June 05, 2022, 11:30:08 AM »
What is the correct PCV hose for a GT350.  Did Shelby use or modify the Ford C6AZ-6A664-N (PCV to carburetor spacer plate) hose?
Or Did Shelby use another part number hose?
I see this hose listed by Virginia Classic Mustang, however it looks as if it will not work with the PCV hose fitting
I pointing towards 11 O'clock position on the back of the intake.
https://www.virginiaclassicmustang.com/PCV-Valve-to-Intake-Fitting-Hose-for-65-67-GT350-Shelby-P482251.aspx
« Last Edit: June 05, 2022, 11:35:57 AM by S412gofast »
1967 GT350 01341, FORD Build: 2/28/67 ; SAI Build 3/28/67
1966 GT 2+2, 4spd, PS, tinted windows, Raven Black w/Black Pony interior; FORD Build: 10/11/65
1986 SVO, Oxford White w/Leather interior
1987 Saleen #132 Dark Gray Metallic
Re: GT350 PCV Hose
« Reply #1 on: June 05, 2022, 12:11:05 PM »
The process was of modifying (cutting) the stock Ford PCV hose . That practice was started at SA in early 65 production by SA and was continued by Ford Cleveland engine plant for all of the rest of Shelby years of production. The hose that VCM sells will work too but does not look as correct IMO.
« Last Edit: June 05, 2022, 12:14:15 PM by Bob Gaines »
Offline S412gofast
Re: GT350 PCV Hose
« Reply #2 on: June 05, 2022, 12:30:05 PM »
Thanks Bob
