Author Topic: 69 SJ SCJ 4speed close ratio V code 3.91 gears  (Read 1013 times)
Offline keeper
« on: May 28, 2022, 12:16:26 AM »
I was told I needed a gear reducer for the speedometer cable by one expert and another said no, not for the 69 scj 3.91 4 speed car. Please help me get the correct info. as they are hard to find and certainly not cheap. Thank you in advance for any leads.
« Last Edit: May 28, 2022, 02:20:53 AM by keeper »
Keith 69 Mach1TopLoader/Vcode SJ
Offline rockhouse66
Re: 69 SJ SCJ 4speed close ratio V code 3.91 gears
« Reply #1 on: May 28, 2022, 07:41:09 AM »
What is the build date of the car?  Makes a difference in the answer.
'66 GT FB
Offline DragPack69
« Reply #2 on: May 28, 2022, 07:49:21 AM »
Check the information on the cj site.
Scott has the answer there
Jimis correct
Build date is the key
Offline Vcode
« Reply #3 on: May 28, 2022, 08:53:05 PM »
Offline keeper
« Reply #4 on: May 29, 2022, 04:35:22 PM »
It was built 3-20-1969.      V-Code , thank you for the documentation. Looks like my build date exempts me from needing the reducer. Thank you all for the input.
« Last Edit: May 29, 2022, 04:39:16 PM by keeper »
Offline rockhouse66
« Reply #5 on: May 29, 2022, 09:17:09 PM »
I agree - no reducer.  But your transmission speedo drive gear will need to be the correct one for this time frame (not the same as the drive gear used with the reducer).
'66 GT FB
Offline keeper
« Reply #6 on: May 30, 2022, 03:11:23 AM »
Thank you and I will make sure it is correct. Knowing the restoration was done using mostly oem parts I believe it is correct.
Offline 69supercj
« Reply #7 on: August 26, 2022, 01:04:04 PM »
So from what I gather from the CJ site, all 69 V or W code C-6 equipped cars used the reducer?
Offline sah62
« Reply #8 on: August 27, 2022, 08:34:16 AM »
Yes, that's what our research seems to indicate.
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline keeper
« Reply #9 on: September 09, 2022, 04:21:05 PM »
According to the link from V Code that is not the case that all V codes and W codes used the gear reducer.
« Reply #10 on: September 09, 2022, 07:49:21 PM »
Correct it depended on when the car was assembled for the speedo adapters
Offline keeper
« Reply #11 on: September 10, 2022, 02:43:15 AM »
It does appear that all automatic trany's did use the gear reducer regardless of assembly date. Interesting.
Offline rockhouse66
« Reply #12 on: September 10, 2022, 08:26:15 AM »
I have never had a C6 apart but isn't the speedo input gear made on the shaft and not removable?  If so, then that gear ratio is fixed (unlike the 4-speed) and a reducer would be required with all 3.91 and 4.30 geared cars.
'66 GT FB
« Reply #13 on: September 10, 2022, 02:45:10 PM »
Yes but that's a little off thread  ;)
