Author Topic: 10" Drum Brake Hold-down Spring Lengths  (Read 1404 times)
Offline Angela
« on: May 23, 2022, 09:19:49 AM »
Based on a collection of old used hardware, I believe Ford used two different length hold-down springs on the rear axle. While I am not sure it matters, it would be neat to understand which shoe (primary or secondary) was supposed to use the longer spring.
When I say "hold down spring", I'm referring to the ~1" long springs which use the cupped washers and retaining pins.
I haven't run across a set of repro hardware with different length springs, hence I doubt it matters much. Regardless, if anyone knows which shoe used the longer spring, I would appreciate knowing this detail. Thank you.
Offline rockhouse66
Re: 10" Drum Brake Hold-down Spring Lengths
« Reply #1 on: May 23, 2022, 12:48:02 PM »
Different width rear shoes used different length pins and springs.  There is a wide and narrow choice.  Maybe not your question, but it could be  ;)
'66 GT FB
« Reply #2 on: May 23, 2022, 09:06:47 PM »
I checked into this as well and there are different heights, different colors and some application used a different spring for each of the primary and secondary shoes.
Note that the data I found was in the 60-68 MPC and not field study.
Offline kitdoctor
« Reply #3 on: June 10, 2022, 01:53:38 AM »
I did some research into this to identify part numbers and typical spring colours/colors.  The primary shoe spring is dual diameter and can be a light or very dark green.  The secondary spring is typically yellow. The drum brake adjusting screw is typically a medium blue.  The parking brake spring is typically maroon.  The shoe retaining springs are a very light blue.  These are the only ones I could not find a photo of showing and NOS part.
This is an unrestored Boss 351.
Dirty laundry list:
'70 Torino Cobra SCJ Medium Red, C-code, 24k miles
'70 XW GS Fairmont Diamond White, auto, 40k miles
'71 Boss 351 fastback Grabber Yellow 5k miles
'73 XA GT sedan Lime Glaze, 4 speed, 81k miles
'77 XC Fairmont GXL Onyx Black, 4 speed, 29k km
'78 P6 LTD Sno White, auto, 160k km
Offline kitdoctor
« Reply #4 on: June 10, 2022, 01:55:52 AM »
Primary spring.
Dirty laundry list:
Offline kitdoctor
« Reply #5 on: June 10, 2022, 01:57:15 AM »
Secondary spring found in a latter service part kit.
Dirty laundry list:
Offline kitdoctor
« Reply #6 on: June 10, 2022, 01:58:31 AM »
Adjusting screw.
Dirty laundry list:
Offline kitdoctor
« Reply #7 on: June 10, 2022, 01:59:55 AM »
Parking brake spring.
Dirty laundry list:
