Author Topic: Temp sender  (Read 1409 times)
Offline Beeler422
Temp sender
« on: May 16, 2022, 02:58:59 AM »
On a gt350, where is the temp sender located on the replacement intake and how is it wired? Anyone have a picture and part number of an original?  Mine was modified at some point in the past.
Also, without starting another thread, does anyone restore shift knobs or have any tips?  The chrome under the clear epoxy needs refinishing on mine.
Thanks.
« Last Edit: May 16, 2022, 03:07:40 AM by Beeler422 »
Re: Temp sender
« Reply #1 on: May 16, 2022, 08:42:23 AM »
It is located just behind the T-stat housing, same as the cast iron intake. The wire is in the engine harness which includes the oil pressure sender, coil power and the temperature sender.
Re: Temp sender
« Reply #2 on: May 16, 2022, 05:00:47 PM »
Top row with cast iron intake and bottom row with the aluminum
Water temp senders would have not been painted over like shown in the upper left. Just some owner with a rattle can  ::)
« Last Edit: May 16, 2022, 05:14:20 PM by J_Speegle »
Offline Beeler422
Re: Temp sender
« Reply #3 on: May 16, 2022, 05:20:51 PM »
Awesome. Thanks.  What is just to the left of the sender in the bottom 2 pictures?  That is where my sender currently.
Re: Temp sender
« Reply #4 on: May 16, 2022, 05:24:54 PM »
That first threaded hole left of the sender in the pictures is where the heater hose fitting goes .
Offline Beeler422
Re: Temp sender
« Reply #5 on: May 16, 2022, 09:57:33 PM »
Got it.  I see what's been done.  Thanks!
