Author Topic: Kick Panel Rivet  (Read 436 times)
Offline Keith Stem
Kick Panel Rivet
« on: May 09, 2022, 11:09:05 AM »
I judged a 68 at the MCA show in Florence SC, both kick panels had a rivet in the upper rear section. The owner did not know why the rivet was there. The other two judges had not ever seen a rivet in a kick panel. After the owner received his judging sheet, he found a Mustang salvage yard that had a rivet in both kick panels (His Pictures Attached). Has anyone ever seen this and why are they there?
Offline Coralsnake
Re: Kick Panel Rivet
« Reply #1 on: May 09, 2022, 12:08:17 PM »
Did you happen to note the plant and time frame?
« Reply #2 on: May 09, 2022, 12:53:03 PM »
Sometime in the 1968 model year the hole was relocated in both kick panels. As there was already a supply of kick panels in stock the extra holes were simply plugged with a pop rivet. The change affected both Mustangs and Cougars. The Cougar kick panels were made from Mustang kick panels. The difference - Cougars had speaker holes heat stamped in the panels.
I've noticed these pop rivets in seemingly unmolested cars from around December 1967 - January 1968. I don't think any were from San Jose, only Dearborn.
Offline Keith Stem
« Reply #3 on: May 09, 2022, 02:05:22 PM »
This car was a 68CJ. I do not know the build date, but it was a Dearborn car.
Thanks for the reply, the panels in the picture are most likely original.
Keith
8F02R185596
Offline preaction
« Reply #4 on: May 09, 2022, 02:44:37 PM »
Keith, thanks for posting this as I lost track of it since Florence. So it seems to be a legit installation for the time frame.
« Reply #5 on: May 09, 2022, 04:31:44 PM »
