Author Topic: 68 GT C Stripe  (Read 952 times)
Offline adam8888d
68 GT C Stripe
« on: May 03, 2022, 02:11:42 PM »
Could anybody please tell me if the C stripe was only available in flat white or was there a metallic or a reflective white available also on the 68 GT fb? Regards
Re: 68 GT C Stripe
« Reply #1 on: May 03, 2022, 03:45:07 PM »
Select Search
Enter: 68 gt reflective
Many, many threads . . .
Offline Coralsnake
Re: 68 GT C Stripe
« Reply #2 on: May 03, 2022, 03:57:33 PM »
I believe they were reflective and non reflective.
Re: 68 GT C Stripe
« Reply #3 on: May 03, 2022, 08:54:38 PM »
The reflective was a separate option which would have been the stripe and wheels. GT or Sprints would have had plain stripes unless they also checked the reflective box.
Offline dkknab
Re: 68 GT C Stripe
« Reply #4 on: June 25, 2022, 11:12:52 PM »
And was the C stripe on Sprint cars painted or vinyl? Mine is vinyl and sure does look like it was masked off and painted around when my car got a new paint job which makes me think it was original to the car.
David Knab
289 2V, AT, PS
Nugget Gold Interior
Re: 68 GT C Stripe
« Reply #5 on: June 25, 2022, 11:16:17 PM »
They were a sticker/tape from 3M material from the era
Offline dkknab
Re: 68 GT C Stripe
« Reply #6 on: June 26, 2022, 08:42:20 AM »
Aha. That makes a lot of sense since it is a pretty complicated stripe.
That being the case I was docked 2 points at Florence a you can see on my sheet.  It clearly says GT/CS stripe not painted but I have a Sprint B.  Do you suggest I reach out to MCA to suggest a change to the grading sheet to include Sprint B in the description?
David Knab
289 2V, AT, PS
Re: 68 GT C Stripe
« Reply #7 on: June 26, 2022, 09:27:52 AM »
It is very common knowledge that the GT stripe is vinyl, the same stripe is used on the sprint B so I see no need for a rule change. It is very unusual to paint around a stripe and I think your judges mistook the paint line from the repaint as a painted stripe.
Offline dkknab
Re: 68 GT C Stripe
« Reply #8 on: June 26, 2022, 11:10:38 AM »
I was confused by what they meant because they wrote "stripe is vinyl" which I thought they were stating a fact yet they deducted 2 points.  Any suggestion as to if I point this out to judges in the future?
David Knab
289 2V, AT, PS
Re: 68 GT C Stripe
« Reply #9 on: June 26, 2022, 12:43:17 PM »
You can point it out if you wish but you are sure to get a deduction for the paint line around the stripes.
Offline dkknab
Re: 68 GT C Stripe
« Reply #10 on: June 26, 2022, 12:59:57 PM »
Thanks Marty. I understand that could be the case and it's something I don't think is an easy fix.  As a matter of fact I did lose 5 points out of 25 under the paint workmanship section for the touched up dings on the car. Without a respray of the car it is what it is. Thanks again.
David Knab
289 2V, AT, PS
Re: 68 GT C Stripe
« Reply #11 on: June 26, 2022, 01:21:49 PM »
what award did you receive?
Offline dkknab
Re: 68 GT C Stripe
« Reply #12 on: June 26, 2022, 02:04:01 PM »
I did not receive one at all.  I had 116 points deducted.  But since Florence I have corrected a lot of the errors so I'm hoping for a better result in Evans GA this September.
David Knab
289 2V, AT, PS
