Author Topic: speedometer cable  (Read 898 times)
Offline tclark
speedometer cable
« on: April 28, 2022, 12:06:03 PM »
 My 65 GT speedo quit working I replace the cable, work for about 30 miles then quit took it out and the end was broken at the speedo connection. I installed a new cable and again at aprox. 30 miles or less it stopped again?? could there be something wrong in the odo??
 Thanks for any info.
Tom
Re: speedometer cable
« Reply #1 on: April 28, 2022, 02:26:39 PM »
Did you replace the cable and the housing?
« Reply #2 on: April 28, 2022, 03:23:31 PM »
The speedometer can be tested with a cordless drill, find a fitting to go into the input shaft and give it a whirl.
Could be an issue at the trans.
Otherwise, proper routing might be the issue.  4sp and automatic trans cable routing is different.
