Author Topic: #2 Crossmember (Removable Tube) Attaching Bolts  (Read 787 times)
« on: April 23, 2022, 11:04:32 PM »
A request for some information and pictures of the attaching bolts that hold the somewhat glossy black removable cross member to the front frame rails came up in one of the Members Build threads and since those and some other sections cant be see by non-members I thought I would also post them here in an effort to provide support and information to all. Hope this helps others
From a late 68 San Jose Mustang. If your wondering about the red safety coloration of the lower control arm adjusting bolt this was a new thing introduced in 68 (big focus on safety marks) but the forward washer is not dyed.
Re: #2 Crossmember (Removable Tube) Attaching Bolts
« Reply #1 on: April 24, 2022, 12:36:28 AM »
Do you have a pic of the cone/ taper shape under the bolt head that centers the support hole on the cone area?
« Reply #2 on: April 24, 2022, 12:43:18 PM »
No. But AMK does. 379068-S.
« Reply #3 on: April 24, 2022, 06:55:42 PM »
Looked and it appears no I don't have a good picture of either the threaded section with the guide tip nor the tapered section of the head that centers the cross member, only more of the head design I must have been focusing on at the time
« Reply #4 on: April 24, 2022, 07:09:11 PM »
Figured I would do a quick search of Epay and came up with these shots though each were not identified as to year and plant
Lower right was identified as a Drake reproduction. Notice that the head markings are different from the examples posted. They may again have used a later service replacement for the pattern. Looks to be the same supplier with an updated marking design
« Reply #5 on: April 24, 2022, 08:06:09 PM »
Let me add to the confusion. The bolt in question has a name. It is 379068-S (natural, no finish). To further the confusion, I have determined that the head of this bolt used on 1964 thru 1966 Mustangs were unmarked. No manufacturer or grade markings are on the head. My samples are mostly San Jose. In 1967 (early, mid, late?), a "F" head bolt was introduced, with a grade 5 marking. There are rumored to be other head markings. One I have is a "B" in a "U". That is identified as a reproduction. If so, it was sold at least 20 years ago. Remember, the majority of cars i have access to in the San Jose area were made in Milpitas.
Offline dkknab
« Reply #6 on: April 24, 2022, 08:12:44 PM »
Here are my bolts. Clearly shows an F on the head. In an earlier picture it looks like they have red stain markings.
« Last Edit: April 24, 2022, 08:33:10 PM by dkknab »
David Knab
289 2V, AT, PS
Nugget Gold Interior
Offline dkknab
« Reply #7 on: April 24, 2022, 10:35:44 PM »
Also a question... from the last of the pictures it looks like the bottom of the frame rails are painted red oxide whereas we know the engine area is painted black.  Is that correct that the bottom of the forward frame rails are red oxide not black?
David Knab
289 2V, AT, PS
« Reply #8 on: April 24, 2022, 11:48:51 PM »
The engine compartment and wheel wells (on San Jose and NJ cars) were painted black by painter(s) standing above the car /on the same level. There was no need to bend over and attempt to spray upward so they tried to spray somewhat flat pattern to get the inner and outer edges of the frame rail and that overspray attached to areas/brackets that hung downward allot or a little depending on the angle and how fast a pass was made with the gun. So its very typical in this area of the undercarriage to see either strong showing of red oxide or that with a light misting of black over the surface in some area.
« Reply #9 on: April 24, 2022, 11:49:44 PM »
Read stain may be due to the application of a thread lock material though I don't recall seeing a note about that in the past
