Author Topic: Trunk Light Wire?  (Read 1486 times)
Offline kkupec02
Trunk Light Wire?
« on: April 21, 2022, 10:45:46 PM »
I am guessing that this trunk wire was for the Ford trunk light that Shelby took off when he put on the fiberglass trunk lids?
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
Re: Trunk Light Wire?
« Reply #1 on: April 21, 2022, 11:12:24 PM »
67 Shelby's came to the SA factory without trunklids . There was no taking anything off. SA had to add a trunk light on the cars that got them . On Shelby's typically only early cars and some late cars got trunk lights for what ever reason.
Offline kkupec02
« Reply #2 on: April 22, 2022, 08:19:36 AM »
So this is an unused trunk light wire? Or something else that I am missing?
« Reply #3 on: April 22, 2022, 11:13:34 AM »
On a fastback, there's wiring that runs over the upper back trunk area for the RH side courtesy light.
« Reply #4 on: April 22, 2022, 11:28:15 AM »
That may be a feature of another year. The 67 comes off the A-piller dome light switch, under the sill plate and then to the light.
« Reply #5 on: April 22, 2022, 11:36:49 AM »
I should add that 67 Shelbys had the Courtesy Light Group. As part of this option this wire is run as a traveler taped to the rear harness for the light but not always used. See Bob's post about the trunk light.
« Reply #6 on: April 22, 2022, 12:19:02 PM »
Thanks, 65-66 for sure.  What about wiring for a defroster setup?
« Reply #7 on: April 22, 2022, 01:24:08 PM »
That might be better as a separate thread.
From the assembly manual (and others) there appear to be no wires built into the harness.
I suspect if there was a 67 fastback (not coupe) option for the defrost it was a standalone harness. I've seen 68 fastback rear defrost systems but 67?
Does a 67 factory fastback defrost system exist?
« Reply #8 on: April 22, 2022, 01:36:49 PM »
Not a 67 Shelby Unique Option...any 67 Mustang could be ordered with the Courtesy Group,  and yes (at least on Mustangs) it is a traveler wire taped to the harness every 12 or so inches apart, it connects at the drivers dome light switch within the A-pillar.
« Reply #9 on: April 22, 2022, 04:31:09 PM »
Don't believe so - think its a 68 only thing that didn't sell well
