Author Topic: Battery Heat Shield link broken  (Read 746 times)
Online 67gta289
« on: April 13, 2022, 09:27:53 AM »
I was picking a 68 Montego yesterday with power windows and convenience control - by the way there is a lot of interchange of components with the Mustang on the latter.  In the back seat was a battery heat shield dual marked as C7ZB-10B682-A and C7OB-10A682-A.  I went to the library to check out the battery heat shield link to compare, but the link is broken - https://anghelrestorations.com/uploads/3/1/7/6/3176630/battery_heat_shield_v1.2.pdf.
I did search the site but this was not found.   Any help appreciated
Re: Battery Heat Shield link broken
« Reply #1 on: April 13, 2022, 10:48:56 AM »
A similar situation occurred from another Library link to Marcus' site (last week).
My guess is Marcus updated his site.
Go to Anghelrestorations.com , click on Mustang Factoids, scroll down and click on the BATTERY image
« Last Edit: April 13, 2022, 10:55:28 AM by 67gtasanjose »
Online 67gta289
« Reply #2 on: April 13, 2022, 11:07:30 AM »
Well there it is.  Should have looked closer!
Online 67gta289
« Reply #3 on: April 13, 2022, 05:55:14 PM »
Here are some pictures.  This would be the "early version", and molded in light gray plastic.  It was in the back seat of a 68 Montego MX with AC, which should get a heat shield based on the MPC.  However, a 1968 model year car and a "late 1966 or early 1967" date range don't add up.
There are about 20 1967 model year Mustangs and Cougars here, but none with A/C, which would be what to expect up here in the north.  There is one S code 67 Mustang.  Other than A/C, I don't recall what would drive this being installed on a Mustang or Cougar.
« Reply #4 on: April 13, 2022, 08:04:04 PM »
Your early shield has NOT been shortened for use on a Mustang.
