Author Topic: Rebuild Inner and Outer Tie Rod Ball Joints  (Read 2782 times)
Offline Daven
Re: Rebuild Inner and Outer Tie Rod Ball Joints
« Reply #15 on: April 22, 2023, 06:58:51 PM »
The good tie rod boots sold at NPD are from Scott Fuller.  You can also order them directly from him.  I think the price is about the same from both places.
Offline dkknab
« Reply #16 on: April 25, 2023, 06:52:06 PM »
Thank you goes out to NPD. They sent me 4 new boots no questions asked.  But these are pretty hard... not as flexible as I'd think they should be.  Any thoughts? Thank you again to NPD for sending me boots.
David Knab
289 2V, AT, PS
Nugget Gold Interior
« Reply #17 on: April 25, 2023, 09:12:34 PM »
My thoughts are if it is a Scott Fuller part then use it with full confidence.
« Reply #18 on: April 25, 2023, 10:31:42 PM »
Set them in the sun for a little while and they will likely flex more for the installation. Warm water bath works during the cold part of the year if its a concern
Offline TLea
« Reply #19 on: April 27, 2023, 10:43:55 AM »
The ones from NPD and dead nuts on are the ones made by Scott fuller
Offline dkknab
« Reply #20 on: April 27, 2023, 05:29:16 PM »
That's curious then.  The first ones I got must have been Scott Fuller but are definitely cracking.  I'm going to hold off on replacing them until August just before I go to Melbourne for the MCA show.
David Knab
289 2V, AT, PS
« Reply #21 on: April 27, 2023, 05:31:13 PM »
Might try reaching out to Scott directly to let him know.
https://www.scottfullerreproductions.com/
« Reply #22 on: April 27, 2023, 05:37:24 PM »
I know NPD in the past carried a lower priced alternative to the Scott Fuller boots so the cracked ones might not be his.
