Author Topic: installing A/C line rubber straps  (Read 994 times)
Offline Big Al
« on: April 09, 2022, 06:34:58 PM »
Anyone have a suggestion on installing the A/C lines rubber straps (70 351W 2 Bl) which hold the lines in place to the firewall to shock towers?  Is there a "trick" to popping the brad through the hole in the strap?  I have wrestled with these and no luck.  I have soaped the "pointed brad, but that just makes the strap slippery also.  I am considering enlarging the holes to get it done.   Thoughts, comments, prayers?
Big Al
1973 Mustang Conv and 1970 Mach I
Offline Big Al
Re: installing A/C line rubber straps
« Reply #1 on: April 09, 2022, 06:36:44 PM »
add "Firewall to Shock Tower supports"
Big Al
« Reply #2 on: April 09, 2022, 06:37:53 PM »
Big Al
I enlarge the hole some.Keep extras on hand the repros easily break after a short period of time.
« Reply #3 on: April 09, 2022, 08:31:38 PM »
Wonder if some carefully placed weather strip adhesive would help keep these things in place as we often find them apart
Just a thought - but I've got no cars currently that need these to test in person
Offline Big Al
« Reply #4 on: July 23, 2022, 06:38:23 PM »
Followup
I heated an old Phillips screwdriver end (I had sharpened to a point), for about 20 seconds, with a torch, then gentle probed it thru the selected hole on the strap (for the fastener pointed end), turning over the strap over and repeating this a couple of times until I could see the hole enlarged some, but not too much.  This made a big difference in the pointy fastener "brad" going thru the hole.  Be careful as you can enlarge it too much.
Hope this helps someone else.
Al.
« Reply #5 on: July 23, 2022, 07:49:58 PM »
I just installed some and though a struggle...they do pop in (with no modifications).
Offline 67350#1242
« Reply #6 on: July 24, 2022, 08:33:58 AM »
Quote
What is it with modern rubber? I had 3 of 4 break apart within 1 year - car sitting in garage.
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
« Reply #7 on: July 24, 2022, 11:58:08 AM »
I put a block of wood 5/8" by 1 1/2" by 3" on the shock tower to cowl brace to support the steel rivet. This makes it easy.
« Last Edit: July 25, 2022, 09:08:58 PM by RoyceP »
« Reply #8 on: July 24, 2022, 12:34:34 PM »
A Velcro cord strap used around the lines when not showing or transporting helps keep them from breaking. I would use red ones, so you do not forget to take them off at the show.
« Reply #9 on: July 24, 2022, 04:00:11 PM »
Out of curiosity, what is/are the country of origin? And "who" did you buy them from? A bit of pressure, and feedback, is often beneficial.
Offline 67350#1242
« Reply #10 on: July 25, 2022, 05:41:50 PM »
Quote
Try a nut driver of appropriate size to fit over the cone and use it to press the rubber on.
67 GT350 SJ 2/01/67
« Reply #11 on: July 25, 2022, 09:09:59 PM »
I buy a pack of ten at a time from AMK. Not sure where they come from. Assuming originals were better.
« Reply #12 on: July 25, 2022, 09:26:40 PM »
Not sure of that since few examples have any or all of them even on cars I bought and saw in the 70's
« Reply #13 on: July 25, 2022, 10:55:30 PM »
Originals lasted longer . Back in the early 80's it was not uncommon to find them still intact on the big Fords in junk yards I mostly found them on.  However taking them apart intact was too much to expect and seldom was I successful. They were 20 years old or more by then . You are lucky to get a couple years out of the AMK versions before they start to fall apart.
« Reply #14 on: July 26, 2022, 02:10:50 AM »
Originals lasted longer . Back in the early 80's it was not uncommon to find them still intact on the big Fords in junk yards I mostly found them on....................
Must have been different yards than I visited   But then again in the 70-early 80's not really something I was packing home  ;)
