Author Topic: SWAY BAR End Link  (Read 420 times)
Offline dkknab
SWAY BAR End Link
« on: April 09, 2022, 05:22:16 PM »
Onward replacing the cracked bushings and crusty  bolts on my sway bar link.  They are badly cracked and the bolts are a rusty mess.  What are the finishes of the bolts and nut for my 68? Of course I'm assuming the bushings are black.
David Knab
289 2V, AT, PS
Nugget Gold Interior
Re: SWAY BAR End Link
« Reply #1 on: April 09, 2022, 06:23:48 PM »
have you checked the library section here? or do you have the assembly manuals? both are excellent resources for that type of info.
Offline dkknab
« Reply #2 on: April 09, 2022, 06:33:43 PM »
I did do a search but didn't come up with any info.  Amy help would be appreciated.  Maybe I'm using the wrong search terms/words.
PS I did search on 68 category.
David Knab
289 2V, AT, PS
« Reply #3 on: April 09, 2022, 06:42:43 PM »
The bolt and washers are typically Phosphate and oil ,the spacer is bare steel or zinc silver and the the nut is zinc or cad silver. Just get a AMK kit that comes with everything including bushings in proper appearance.
« Reply #4 on: April 10, 2022, 02:04:36 PM »
And avoid the Scott Drake kit because nearly all the components are incorrect.
