Author Topic: clutch pedal adjustment 64.5 Mustang  (Read 554 times)
Offline CW4macret
« on: April 04, 2022, 11:31:15 AM »
I have been having a problem with the clutch pedal sticking to the floorboard. I completely rebuilt the system and still have this issue no matter if I adjust the clutch to engage low or high pedal travel. Has anyone else had this issue? Anyone figure out how to correct this? Would converting to 66 rods and equalizer fix this?
Mac
64.5, 5F07D
66 Convertible 6T08T
71 Mach1 429CJ 1F05J
01 Coupe
05 GT
08 GT500
14 GT500
Re: clutch pedal adjustment 64.5 Mustang
« Reply #1 on: April 04, 2022, 10:24:08 PM »
Are you using the Ford stock clutch parts and not the centrifugal aftermarket parts?  The latter does have a tendency to cause the pedal to stick to the floor at high RPMs, which isn't what you describe.  The other part that may be missing is the "over-the-center" spring above the clutch pedal.  This HD spring assists in both lowering and raising the pedal.
Offline CW4macret
« Reply #2 on: April 05, 2022, 03:25:32 PM »
Using OEM pedal, equalizer bar and springs, Scott Drake bushings. It does not do it every time. If I am careful and stop about 1/2 from the floor it is fine. Might explain why I have seen a 2X4 under the pedal on some of these early 60s fords in the bone yard. (LOL)
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
