Author Topic: Fastback door window v. Coupe door window bracket differences  (Read 577 times)
Offline hertz350
Here is a picture of a coupe door glass on top of a fastback door glass. There is a difference is the size and shape of the metal that holds the glass. Can you use the coupe metal glass holder for the fastback? I see NPD lists one bracket channel to use on both coupe and fastback
Re: Fastback door window v. Coupe door window bracket differences
« Reply #1 on: April 01, 2022, 12:22:59 AM »
According to the "1966 Mustang Body Assembly Manual", there is no difference between the three body styles in the door windows except the glass assemblies, C5ZB-6321400-1, C5ZB-6521400-1, and C5ZB-7621400-1. All other hardware and unique Mustang designed parts are either a C4ZB- or C5ZB- (except the plugs in the trailing edge of the door).
Note: the glass assemblies are all 1965 assemblies.
I strongly recommend you get a set of "1966 Mustang Assembly Manuals", plus the "64-65 Chassi"s and "64-65 Weld and Sealant" - plus the "1966 Shelby Unique Parts Manual" (all published by Jim Osborn Reproductions).
Offline hertz350
« Reply #2 on: April 01, 2022, 01:21:25 AM »
Thanks, but that doesn't answer my question about whether he metal channels shown are interchangeable? Can I use the coupe glass channel in a fastback?
« Reply #3 on: April 01, 2022, 10:24:19 PM »
There's no difference.  Might be seeing an early vs. late bottom piece.  Do they both have long channels for the window regulator guides or does one have it broken into 2 sections?
Offline hertz350
« Reply #4 on: April 19, 2022, 02:57:48 AM »
They both have the long window regulator guide channel.
