Author Topic: disc brake splash shields  (Read 534 times)
Offline Ashley
« on: March 31, 2022, 08:06:01 PM »
Recently purchased S code coupe San Jose built October 22-66. Anyone know the date brake splash shields were changed to vented style shields. also the date when solid steering shaft was changed to rag joint.
Re: disc brake splash shields
« Reply #1 on: April 01, 2022, 05:59:49 AM »
These are from a November 2nd, 1966 actual build date San Jose example. It has the Earlier Caliper design also.
I cannot give a date on the rag joint detail but I thought all S-codes were rag joints.
« Last Edit: April 01, 2022, 06:02:31 AM by 67gtasanjose »
Offline Ashley
« Reply #2 on: April 06, 2022, 09:49:58 PM »
Thanks for reply, my car was built 10-28-66. Looking for splash shields and calipers, rotor/hub assemblies
Offline 196667Bob
« Reply #3 on: April 07, 2022, 03:22:40 PM »
In a previous Post from 2019, Bob Gaines replied as follows :
"The 390 typically got the short column with a rag joint coupler regardless of if early or late production . It was the smaller displacement engine cars that got the long version column until the changeover to for all cars to the rag joint shorter style regardless of displacement happened in May of 67."
Bob's use of the word "typically" implies that there may have been exceptions, but in general, Mustangs with the 390 had the rag joint with the short shaft steering box.
As for the "May 1967" date, there wasn't any documentation given, so one must assume that it is based on his hundreds of observations.
I have looked in the 1967 Parts and Accessories Catalog, the 1960-68 MPC, the 1965-72 MPC, and every Technical Service Bulletin, page by page, from December 1966 through September of 1967, and none of those references give any date as to the change from the long shaft to the short shaft with the rag joint.
My January 31, 1967 Dearborn built 67 with Factory PS has the long shaft with no rag joint.
In summary, until more exact information is found, May 1967 appears to be when the change was made.
Bob
MCA 04909
« Reply #4 on: April 07, 2022, 05:56:11 PM »
The way I heard it was the big block was so large you could not remove the steering box without removing the engine due to the spear. Small blocks didn't have this issue.
Offline Ashley
« Reply #5 on: April 07, 2022, 08:49:40 PM »
Thanks to all, great info
