Author Topic: Oil Pan Drain Plug Info  (Read 1208 times)
Offline dkknab
« on: March 12, 2022, 05:07:41 PM »
Hello, I clearly have an incorrect drain plug and gasket. Does anyone have pictures of the correct one for my 68 Sprint B with a 289 and where can I get the proper concours plug? In the Mustang 19641/2 - 1973 Restoration book the part numbers listed are 6734 for the gasket and 6730 for the drain plug. There are multiple choices on NPD website. Some with markings on the bolt others with none. Then there is a red gaskket, black gasket, and white one as choices. Which is correct?
Here's a picture of the one I have installed on my car right now.
David Knab
289 2V, AT, PS
Nugget Gold Interior
Re: Oil Pan Drain Plug Info
« Reply #1 on: March 12, 2022, 07:14:14 PM »
The ones that I have seen most frequently on 68 69 are plain with no markings . I have a oil 68 69 302 pan on the shelf and that is what it has. I looked through my box of oil pan bolts and the gaskets seem to be a nylon plastic semi opaque and is yellowy white now. The yellow comes with age I am pretty certain. That is how I remember them also . They were painted on the engine so what ever you use will end up being blue in the end.
Offline outlawincorporated
  • Kangaroo Herder
« Reply #2 on: March 12, 2022, 08:18:48 PM »
Image attached of NOS oil pan plugs i picked up several years these match what i see on 65 66 cars whether they continue through to the 68 i cannot say.
regards
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
« Reply #3 on: March 12, 2022, 10:34:17 PM »
Will look to see if I have a close up of a 68. Not allot of chance that someone would take a picture of an original.
Not certain of the gasket but the white/opaque nylon gasket were included with the aftermarket engine gasket kits of the period, installed a number of them,  so they may have still been metal for assembly line. Will see if I can find some documentation
« Reply #4 on: March 12, 2022, 11:10:10 PM »
Offline dkknab
« Reply #5 on: March 13, 2022, 04:40:41 PM »
From the Text-Engine.pdf of parts that is located in the library section, the Oil Pan Drain Plug for 65/68 is D1AZ 6730-A and the gasket is C2OZ 6734-A. From some pictures I found online it appears there are no markings on the top of this plug and the gasket is white nylon. I've attached the pertinent page from the listing that includes the plug and gasket.
David Knab
289 2V, AT, PS
« Reply #6 on: March 13, 2022, 04:51:12 PM »
That number is a service part issued three years after the car was built. It "may" or "may not" be the same.
Offline dkknab
« Reply #7 on: March 13, 2022, 05:11:23 PM »
Ah hah. Is there a part listing of the original part numbers that were used during the build of the cars?
David Knab
289 2V, AT, PS
« Reply #8 on: March 13, 2022, 07:32:14 PM »
Yes and no. The Mustang Assembly Manuals listed the part numbers of sub-assemblies to be used to build a car, but individual component parts of those sub-assemblies are not normally found. As an example, an engine was delivered to the assembly line almost completely assembled. The "engineering" part number for the crank, rods, cam, etc, are not readily available.
Offline warwick
« Reply #9 on: March 13, 2022, 07:50:26 PM »
My drain plug which I believe to be original-a 68 low mile car with FE engine has a drain plug with the F - C as shown above in Phil's response.
« Reply #10 on: March 13, 2022, 08:05:17 PM »
Have you verified the threads in the pan are ok? That is one weird looking "plug".
Almost looks like a lug nut!
Offline dkknab
« Reply #11 on: March 13, 2022, 08:19:25 PM »
Yes it is.  What are the dimensions of the plug? Is it 1/2" 20 threads?
David Knab
289 2V, AT, PS
« Reply #12 on: March 13, 2022, 11:21:04 PM »
Some examples  Upper left is likely the clearest of the bunch and shows the circle version (8R167xxx)
« Reply #13 on: March 14, 2022, 02:57:59 PM »
From the 60-68 MPC...
« Reply #14 on: March 14, 2022, 05:21:20 PM »
Interesting that Ford stocked that replacement plug for those specific "Specials" With Three 2, two four barrels as single four barrels
Interesting description and why would those be different than other engines.
What year MPC was that scan from?
