After in depth thread searches I only find 2 screw cap positions on the 64.5-65 cars: -the likely 'assembly line' caps on the 3 voltage regulator screw ends in the grille cavity-approx generator post sized-fastback interior trim scew caps for the trunk area - qty 5 used
That style is used in 67 and on.Jim
Marty, the only 1967 use that I recall for the metal capped nuts is in the trunk, retaining the lower back panel grille. As you know these are far and few between, and on the rare occasion that I see them, about half have incorrect mounting hardware. The gray or black plastic caps are not designed to "retain", they are just there for protection.
