Author Topic: Front spindle backing plate gasket 6 cylinder  (Read 769 times)
Offline Colorado56
« on: March 11, 2022, 02:55:59 PM »
Looking at my assembly manual for my 66 cylinder car it shows a gasket in between the spindle and the backing plate. Searched NPD and Virginia Mustang and came up empty.  Any suggestion on where I might find them.
Dave
Re: Front spindle backing plate gasket 6 cylinder
« Reply #1 on: March 11, 2022, 03:34:54 PM »
I've disassembled a few over the years and it was a white spongy gasket material.
« Reply #2 on: March 11, 2022, 05:55:23 PM »
Like a few things you are likely going to have to make some. Should not be difficult
Offline Colorado56
« Reply #3 on: March 11, 2022, 10:33:00 PM »
Would cork be the correct material?
« Reply #4 on: March 11, 2022, 11:20:03 PM »
Have not seen cork... as mentioned in my reply above, I have seen white foam/spongy material on 6 cylinder backing plates.  It was only a dust/dirt seal.   V8's used a paper/fiber gasket, not sure why they were different.
« Reply #5 on: March 12, 2022, 12:38:08 AM »
Sounds like you could use that material I make the 65-66 door plug gaskets from.
Would that be a possibility Charles?
« Reply #6 on: March 12, 2022, 02:07:19 AM »
That would be reasonably close, originals I have seen were a little thicker, more 'spongy'.
Not sure it's a detail even the most seasoned concours judge would be looking for...
