Author Topic: Semi-gloss Black Spray Paint  (Read 7576 times)
Re: Semi-gloss Black Spray Paint
« Reply #15 on: February 26, 2022, 12:26:00 AM »
I bought a can to try on amazon for 18.20 because I am already a Prime member and I get free shipping plus I get it quickly. https://www.amazon.com/gp/product/B00B3I2E0W/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1   . If I like it I can get it at a much lower price if I buy 4-6 cans as Charles suggested.
« Reply #16 on: February 26, 2022, 05:51:19 PM »
Since products are always changing some of us invest a little from time to time to just buy 4-8 different rattle cans, spray them put on a section of metal (I've used a nailing plate often for mine) in one to two inch strips next to each other to compare to original finishes and choose from during a restoration since all of. the black finishes originally were not the same
Also I will test during the process to see which hold up to baking which I've done to make the finish hold up better IMHO over the long haul
Each is labeled on the back side
Just what has helped me in my tasks
Earlier thread on the subject
https://www.concoursmustang.com/forum/index.php?topic=16147.msg101159#msg101159
« Reply #17 on: March 02, 2022, 12:14:05 PM »
I've also noticed that if I preheat or post heat a part -- less than 100 deg. F -- I can get a slightly different gloss level with the same paint brand. Too hot and the paint dries instantly.
Offline Maksim27
« Reply #18 on: March 11, 2022, 01:01:21 AM »
I use Eastwood Extreme chassis black satin aerosol.
I either use black encapsulator or Chassis black primer.
I usually paint after 4 hours when the primer is dry.
Yes it takes 24-48 hrs until the paint is solid and doesn't scratch with a finger nail.
« Reply #19 on: March 19, 2022, 03:34:29 PM »
Sounds like allot of product on the finished part.  Because if this it might not be the best choice for a restoration based on what your describing though it may fit your needs
Just an observation
Offline Countrysquire
    • Houston Vapor Blasting
« Reply #20 on: July 27, 2023, 11:58:11 PM »
Bringing this old thread back up since I finally got to try the 3680102 SprayMax that Charles recommended. This is what I was looking for, a deep black on the surface, a nice satin luster, and dries quickly. To my eye it has the factory appearance that I was looking for.
Bobby Crumpley
MCA#20316
www.houstonvaporblasting.com/
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
Offline 69bossnut
    • DSD Restorations LLC
« Reply #21 on: August 08, 2023, 07:57:54 PM »
DAVID DAVIS
DSD RESTORATIONS LLC
5075 E. COUNTY RD. 126
BLYTHEVILLE, AR. 72315
870-780-4999
dsdresto@gmail.com
www.dsdrestoration.com
Offline lightwtjet
« Reply #22 on: August 09, 2023, 01:00:42 AM »
Here is what I have found-
Krylon Fushion  Matte Black  Slight Gloss  $7 at Wallmart
Krylon Fushion  Satin Black   Moderate Gloss  $7  Wallmart
Last coat quite wet   Spray can paint has come a long way.
1968 CJ - Owner and paint original. Dec 67 build in Dearborn. One of 50 135 Cobra Jets. Ford engineering used it for 8 mos. to resolve problems in the 50 early car build. Ford by-passed the normal sign off to get cars to the Winternationals drag race.
