Author Topic: Torque Converters  (Read 724 times)
Offline 9F94M567042
Torque Converters
« on: February 17, 2022, 03:34:39 AM »
Hey All,
Recently came across some used 60's torque converters. Was wondering if they can be cleaned at all or are they just large paper weights?
These were stored WITHOUT anything protecting the input shaft so who knows what is inside. Dirt/dust/bugs/old fluid/???
Offline 70-Conv_4sp
Re: Torque Converters
« Reply #1 on: February 17, 2022, 02:23:34 PM »
Years ago we did what was a converter flush, using a machine under air pressure and a cleaning agent, if you can find a long time transmission shop
they may still do it. The major things to address are, 1) the neck is not damaged, 2) internal pump splines are not stripped and the one way clutch
internally functions. Most of the time they were still good, you could also turn them in as cores, or as you stated use as paper weights (haha)
70-Conv_4sp
