Author Topic: Thread searches  (Read 1563 times)
Offline preaction
Thread searches
« on: February 13, 2022, 05:25:21 PM »
When using the search feature does a section need to be used for example 1969 Shelby or when  69 shelby is entered into the search bar the entire web site data is searched ?
Re: Thread searches
« Reply #1 on: February 13, 2022, 06:26:09 PM »
Unfortunately I don't see any option to limit or restrict the search to one section or area of the site. Only Subject - all or any words. Poster - Order of findings and how old the post is
Offline preaction
Re: Thread searches
« Reply #2 on: February 14, 2022, 03:36:04 PM »
Thanks Jeff, that does help.  ;)
Re: Thread searches
« Reply #3 on: February 14, 2022, 05:08:58 PM »
There is a search box on the top right just under the picture.
If you are at the top level "HOME" it will search everywhere.
If you are in the 69 section it will only search in that section. Since the whole site is tree based it depends on what part of the tree you are in as to how many levels down it will search. But it will restrict searches to just that section (and any of its branches).
If you used the advanced search section (in the horizontal button area starting with "Home Help
Search . . ." you can restrict the search to any subsection of the site. Or many subsections depending on how many checkboxes you have selected. Or do a global search by leaving the "all" checkbox checked.
Also if you are in one thread (say a build thread of one user) you can use the top right search box to search just the current thread. It is very context sensitive.
« Last Edit: February 14, 2022, 05:12:48 PM by Bossbill »
Offline preaction
Re: Thread searches
« Reply #4 on: February 14, 2022, 05:31:57 PM »
Thanks Bill, I have out of habit been using the search "bar" in the upper right of the page and lost sight of the search feature with the fine tune "features".
Re: Thread searches
« Reply #5 on: February 14, 2022, 07:43:50 PM »
If I don't get immediate satisfaction from the embedded search, I usually head to Google so I have access to advanced search operators, so that I can get the focused results I'm looking for.
Re: Thread searches
« Reply #6 on: February 14, 2022, 07:46:56 PM »
Another option is to use google for searches, like:   "firewall pad" site:concoursmustang.com
Sometimes that works better.
Re: Thread searches
« Reply #7 on: February 14, 2022, 10:10:15 PM »
Building on that, here are some more Google search examples:
1. "firewall" site:concoursmustang.com
Results: all posts that contain the text string "firewall" (on this website)
2. "firewall pad" site:concoursmustang.com
Results: all posts that contain the exact text string "firewall pad" - note that "fire wall pad" would not be in the results due to the space between fire and pad.
3. "fire" "wall" "pad" site:concoursmustang.com
Results: all posts that contain the ALL three text strings, including "firewall pad", "fire wall pad" etc.
4. "front" "bumper" "67|68" site:concoursmustang.com
Results: all posts that contain "front" AND "bumper" AND (67 OR 68)
I have not yet figured out how to, for example, use Google to focus the search in the unrestored pictures section.  A use case - let's say I'm looking for examples of an unrestored 1969 car with red interior, or unrestored 1968 car with interior decor.
« Last Edit: February 14, 2022, 10:12:34 PM by 67gta289 »
Re: Thread searches
« Reply #8 on: February 14, 2022, 11:26:56 PM »
Click on the link for the sub-forum and copy the url to use in the search...
Re: Thread searches
« Reply #9 on: February 15, 2022, 03:35:00 PM »
For instance for 69 go to Home and then select the 69 Mustang bullet. Copy the url. Paste and prepend "site:"
Append what you want in the double quotes (not required if you only search for one word).
site:https://www.concoursmustang.com/forum/index.php?board=4.0 "battery cable"
This a Google only construct -- so trying this while using other search engines will not work.
If you only want pictures then select "images" from the Google tab.
Re: Thread searches
« Reply #10 on: February 15, 2022, 06:42:41 PM »
Must be doing something wrong. Just tried that (using the search button in a specific year section) and got results from multiple years
Re: Thread searches
« Reply #11 on: February 15, 2022, 07:38:36 PM »
Did you use the search box in the upper right just under the horizontal yellow/orange bar?
Re: Thread searches
« Reply #12 on: February 15, 2022, 10:09:00 PM »
Thanks Bill was using the other search button on the page   ::)
Sure this will help others
« Last Edit: February 15, 2022, 10:24:47 PM by J_Speegle »
Re: Thread searches
« Reply #13 on: February 16, 2022, 06:25:28 AM »
This has been very helpful indeed.  For the first time I took a deeper dive into the site-based search capabilities, and noticed a few things I never noticed before:
1. The default "Match all words" (logical AND) can be changed to "Match any words" (logical OR)
2. Instead of being limited to searching all "boards" or just one, you can first uncheck the "check all" selector box, then expand the "Choose a board to search in, or search all" and select one to many boards to search in.
See the pic.
Offline preaction
Re: Thread searches
« Reply #14 on: February 16, 2022, 01:15:58 PM »
Very interesting I have not seen that before.
