Author Topic: Help with correct finish on automatic shifter linkage rods.  (Read 572 times)
Offline Mad4wd
« on: February 07, 2022, 03:32:01 PM »
70 Mach 1 428 C6  Dearborn Early Car
Looking for what the shifter rod and the lockout rod finish should be.  The MCA guidelines if I am reading them correctly state "Cadmium finish, including 70 lockout rod"
So would that be Silver or Gold Cad or something else? I assume that is for both rods. I looked in all the unrestored pics but I can't seem to find a good underneath photo showing linkage clearly.  The ones I do see seem to be more of a P&O or dark phosphate finish
I know the kickdown rod is yellow cad.
1967 FB GT, A Code, 4 Sp MT, 7T02A280XXX, 07/06/67
1968 FB GT, S Code, 4 Sp MT, 8T02S146XXX, 01/05/68
1970 Mach 1, R Code, C6 Auto, 0F05R101XXX, 08/19/69
1970 Boss 302, G Code, 4 Sp MT, 0F02G195XXX, 06/04/70
Offline ExportMach
Re: Help with correct finish on automatic shifter linkage rods.
« Reply #1 on: February 08, 2022, 09:04:21 PM »
On pg 55 of the Osborne Chassis assembly manual there is a small table thats gives the rod colors (silver, red & yellow) for the three different automatics. The C6 is shown to have a red shift rod (D0ZA-7340-B) & lock rod (D0ZE-7E330-N)  I assume they are all Cad plated. If you dont have a chassis manual I will post a pic.
Also, I looked at the Ford Listing of Numerical Finishes to see if I could determine what type of finish Cadmium is and I think youre looking at S39, Cadmium plate 0.0005" (electrolytic or mechanical).
« Last Edit: February 09, 2022, 12:17:17 AM by ExportMach »
Mark C
« Reply #2 on: February 09, 2022, 08:29:42 PM »
All I can offer. At least on the lock out it may have been zinc dichromate and over years lost the gold dye or just cad.  from two different unrestored cars
