Author Topic: Correct Timing Pointer for '69 351W?  (Read 6630 times)
Offline drummingrocks
« on: March 06, 2011, 10:24:44 PM »
It's me again, Margaret!   :D  Seriously, I'm close to getting this hodgepodge of parts back together into a concours looking 351 Windsor.  Can anyone confirm what the original timing pointer should look like on a '69 351W?  I'm looking for a used one, but I've come across two styles and I need to know which is correct for my application.
Style 1: http://cgi.ebay.com/ebaymotors/1968-69-FORD-MUSTANG-289-302-351W-TIMING-COVER-POINTER-/380320532963?pt=Motors_Car_Truck_Parts_Accessories&hash=item588cdec9e3#ht_558wt_1165
Style 2: http://cgi.ebay.com/ebaymotors/69-70-Ford-Mustang-Timing-Pointer-289-302-351W-/370463794732?pt=Motors_Car_Truck_Parts_Accessories&hash=item56415ce62c#ht_500wt_956
As always, thanks a million!
Offline Andrew@MagMustangs
    • MagMustangs
Re: Correct Timing Pointer for '69 351W?
« Reply #1 on: March 07, 2011, 01:47:07 AM »
Depends on your Timing Cover and the bolt Location on it for the pointer, as this changeover happened Mid-Point in the year. Not sure of the exact date. Someone here most likely knows more on this subject. With your Very Late Build Date, I would lean towards the Later Version. One Pointer Mounts on LH Side of Timing Cover, One Mounts on RH.
« Reply #2 on: March 07, 2011, 12:09:22 PM »
Thanks for the reply.  The car was built on June 5th, 1969, so it's fairly late in the model year.  Would a picture of the original timing cover help determine which pointer it used?
    • MagMustangs
« Reply #3 on: March 07, 2011, 03:56:00 PM »
Yes, a picture will help. What are the number Stampings on it?
« Reply #4 on: March 07, 2011, 04:45:52 PM »
I've got the pictures taken, but I'll have to wait until I get home tonight to upload them.  The casting number on the cover is C9OE-6059-A.
    • MagMustangs
« Reply #5 on: March 07, 2011, 05:16:23 PM »
The C9OE-A cover uses the Ds/Lh Pointer, Option 1. on your initial post. Make sure this is a Date Matching cover. there will be a Year inside a Circle, (69) surrounded by Dots......... Count the Dots for a Month Code.
« Reply #6 on: March 07, 2011, 10:24:25 PM »
Here's a couple of pictures of the timing cover.
    • MagMustangs
« Reply #7 on: March 08, 2011, 01:34:51 PM »
Yes, that cover uses the LH Timing Pointer Mount. I see 5 Dots ..... for the Month, if there is a (69) Stamped in there, then I would deem it Date Correct for your Car.
« Reply #8 on: March 08, 2011, 02:55:57 PM »
Great!  Thanks for your help!
