Author Topic: Water Pump variations, small block Ford  (Read 1013 times)
Offline KevinK
« on: January 29, 2022, 11:12:47 PM »
I was at a swap meet today and ran across a water pump which hard a full exposed impeller. It was in a Ford or Motorcraft box. This got me wondering about the various types that were used. Since rebuilt water pumps are pretty much a thing of the past it would seem wise to collect the correct Ford housings for future rebuilding.
Is there a document identifying these water pumps. 64-95
-early aluminum
-cast iron
-aluminum
-short nose
-reverse rotation
These are just a few of the variations I have heard of. And of course there is probably some matching to the front housing variations.
MCA #33800, Gold Card 3rd Gen
BAMA Member
Re: Water Pump variations, small block Ford
« Reply #1 on: January 30, 2022, 07:29:10 AM »
While water pump rebuilding is certainly not as prevalent as in the past, it is not extinct.  If you want the name and number of the guy near me in Dearborn that does it, send me a PM.
Offline KevinK
« Reply #2 on: January 30, 2022, 11:44:36 AM »
Thanks John.
Actually the purpose of the post is to identify the cores I would to collect first. My cars are not rare so I didn't think the info was easy to find in one place.
BAMA Member
« Reply #3 on: January 30, 2022, 12:07:39 PM »
Your question is too broad to answer. There is no document to identify a wide range of water pumps. Perhaps a rebuilder would have something like (multiple documents identifying the specifics of each pump) that as a trade secret. I doubt they would share it without compensation.
Thanks John.
« Reply #4 on: January 30, 2022, 12:11:50 PM »
If you are focusing on the 221/260/289/302/351w I would think that Bob Mannels book would be the place to start.
« Reply #5 on: January 30, 2022, 02:32:53 PM »
Agreed. However the 351W is not included. The chart included both casting and engineering numbers.
« Reply #6 on: January 30, 2022, 05:04:32 PM »
Might also consult and exchange manual (like Chilton's) also. These use to be used by yard to identify what parts could be sold or used to replace a part a customer was looking for. For the 90's I think these would be software based where older ones with in book form
« Reply #7 on: January 30, 2022, 10:19:12 PM »
Yes, Bob Mannel's book explains them pretty well. Some are also coupled with specific timing chain covers.
Offline KevinK
« Reply #8 on: February 13, 2022, 04:08:12 AM »
I have not tracked down the Bob Manuel book yet. I am focusing on the SB Fords from the mustang generations.I have learned a bit so far. I did not know the early mustangs used a very different water pump with an aluminum housing. Most of the 66-78 pumps were cast iron. I will look into collecting more info on these.
There is no need for me to focus on the rare and special versions. I'm sure those who need them are hunting them down. I think there is a short version too.
That leaves the 79-93 versions. I did find an interchange manual in my library by Ford p/n.
79-84 seems to be all the same 4.2/5.0
85 has 2 versions. This about when they reversed the impeller.
86-89 seems to be another version.
90-92 is another version
93 is yet another.
No details on casting IDs but I probably have 2-3 hanging around.
BAMA Member
