Author Topic: Dimmer switch rubber cover  (Read 922 times)
Offline hertz350
« on: January 25, 2022, 01:39:43 AM »
Did March 66 SJ built cars have the rubber cover over the floor headlight dimmer switch?
Offline outlawincorporated
  • Kangaroo Herder
Re: Dimmer switch rubber cover
« Reply #1 on: January 25, 2022, 02:01:16 AM »
NO, believe only convertibles had the rubber dimmer switch cover
regards
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
« Reply #2 on: January 25, 2022, 02:07:14 AM »
+1, if I remember right, it is called out in the Ford assembly manual as a convertible (body code 76) item only.
Offline hertz350
« Reply #3 on: January 25, 2022, 12:01:59 PM »
Thanks, guys.
« Reply #4 on: January 25, 2022, 09:06:17 PM »
My question is why only convertibles?
I understand that the convertible has the extra sill on the  inside...
« Reply #5 on: January 25, 2022, 10:29:25 PM »
My guess is for water/moisture protection in case it rains with the top in its stored (up?  Down?) position.
« Reply #6 on: January 25, 2022, 10:56:47 PM »
More like so your foot would not slip off the smooth metal top when wet. All of the other foot activated items like gas ,clutch, brake had rubber or plastic traction enabled surfaces.
« Last Edit: January 26, 2022, 04:14:19 PM by Bob Gaines »
« Reply #7 on: January 26, 2022, 06:02:55 AM »
This "convertible only" detail has always puzzled me.
I own a convertible Mustang and wouldn't ever consider taking any chance of rain with the top down. Clearly, other people must leave their top down more than I do. I simply don't see the "why" behind this detail.
Offline 196667Bob
« Reply #8 on: January 30, 2022, 01:19:13 PM »
Richard : I agree, that in "today's world" with our cars, chances of this happening are slim. However, "back in the day:, when our cars were sold as "Daily Drivers", Chances of this happening were much more prevalent. In the mid 60's and early 70's, I can't tell you how many times I got "caught" in my 57 Retractable with the top down, and one of those Midwest showers popped up.o frequently, that I kept a towel under the seat just to dry things off after I put the top up. However, once I Restored it in 1976, only once or twice do I remember getting "caught", and one of those was at a National Meet. So, Bob's first sentence in his Reply above, makes good sense.
There is also the case of being out the day after a rain, and stepping in a puddle just before entering your car. But this case seems to reinforce Bob's second sentence, which makes the case for, "why not every Model, not just convertibles" ?
In a quick look at my 66 and 67 Electrical Assembly Manuals, I did not see the rubber cover noted, It does, however, appear in the 1965-67 Parts and Accessories Catalogs (single year MPC's) and the 1960-68 and 1965-72 MPC's ; all list it for only Model 76 Mustang - Convertibles. The 1965-72 MPC shows it  for all 1965-72 Mustang Convertibles.
Bob
« Last Edit: January 30, 2022, 01:27:20 PM by 196667Bob »
MCA 04909
« Reply #9 on: January 30, 2022, 01:39:34 PM »
There is another possibility - esthetics, or appearances. The forward interior of an early Mustang convertible with its top down has roughly 180 degrees of visibility from the rear. The "ugly" metal of the foot actuated switch stood out like an ugly metal foot activated switch. The "rubber" cover made it less "ugly". Don't laugh. Ford made other decisions that are topics of discussion.
While we are discussing the "ugly" metal switch, did the factory carpet have a plastic ring in the hole for the switch; or was it just a "hole"; or was it stitched like a "button hole"?
« Reply #10 on: January 30, 2022, 02:19:54 PM »
No grommets were used nor was the hole stitched. Just a raw hole cut in the carpet, at least it is the way in our unrestored 68 San Jose HCS coupe.
« Reply #11 on: January 30, 2022, 02:23:38 PM »
+1 to marty's reply. nothing fancy there.
« Reply #12 on: January 30, 2022, 02:40:06 PM »
Which is what I thought, it's not an "option", thanks.
« Reply #13 on: January 30, 2022, 04:58:11 PM »
The decorative ring first seems to have appeared with the first replacement carpets of the 80's so even cars with very old looking carpet can be found with this detail  and can often be a first or quick suggestion that the carpet has been replaced.
« Reply #14 on: January 30, 2022, 08:41:59 PM »
Convertibles had inner rocker panels, so it most likely had to do with the position of the switch.
