Some more detail from Ford documentation:
CADMIUM PLATE. This finish is an electro-deposit of cadmium.
Parts plated under this Specification will have a minimum coating
thickness of .0005 in. and must withstand a 96 hour salt spray
test on significant surfaces, except on threaded areas, etc. as
per ASTM B-117. Process Standard P-41-A. The minimum pitch
diameter of external threads before plating may be reduced below
the tabulated minimum by an amount equal to .003 in. minus the
allowance for the thread class. The minimum major diameter may
be reduced by .002 in. minus the allowance.
