Author Topic: 1970 Coil Spring finish  (Read 963 times)
Offline BHStang
« on: January 21, 2022, 12:51:18 PM »
Trying to find what the correct finish should be on my front coil springs.  Reading different posts I have gathered they should be heat treated bare steel similar to the leaf springs in the rear?  Also should have paint stripes for identification but my build sheet is long gone.  Car is DAP June 10 build Mach 1 351C-2v 4 speed with AC.
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
AC, PS, Power disk, Shaker, Rear Spoiler
Re: 1970 Coil Spring finish
« Reply #1 on: January 21, 2022, 02:50:45 PM »
I would treat them the same as the rear leaf springs to duplicate the original oil quenched heat treated steel. Often service replacements were painted black (front and rear springs) to protect the metal while on the shelf/in storage waiting for installation
Will see if I have a matching build sheet
Offline BHStang
« Reply #2 on: January 24, 2022, 09:30:48 PM »
thanks Jeff.  Let me know if you find detail.
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
« Reply #3 on: January 24, 2022, 10:25:10 PM »
Don't have a copy of a similar car. Have 4 speeds without AC or auto with AC
For other cars I found (for the front springs) Gold-Orange or Gold-Tan
Sorry could not find a match for your car in what I've got copies of or in pictures
Offline Skidoodave
« Reply #4 on: January 24, 2022, 10:52:09 PM »
Not sure if this helps as mine is a jersey built car. June 22nd, 1970 H code Mach 1 with an FMX and factory air.
Offline Kdclem
« Reply #5 on: January 30, 2024, 02:03:44 AM »
Yep, that pretty much confirms it.  Autopmatics were GOLD/TAN for coil springs.  Wish I could see one or two other build sheets that have GOLD/ORANGE for 4 speed cars.
Thank you for sharing.
« Reply #6 on: January 30, 2024, 06:45:45 PM »
Unfortunately no that doesn't help. That is not a match for the markings the OP was looking for  ::)
