Author Topic: New theme and modification installed  (Read 1417 times)
Offline Sluggo
  • Dark Overlord
« on: March 04, 2011, 08:21:38 PM »
Hello all!
I have installed a new theme that will make viewing your favorite Mustang board much easier with your smart phone.
I've also installed a modification that will switch to the new theme when you connect using your smart phone. Just tried it out with my android and it seems to work fine.
Also should work with windoze phones, i-phones and blackberrys.
Please use this thread to alert me as to any issues. This is technically still a beta, so there could be a bug or two in it.
You can switch to the mobile theme to see what it will look like(which will open in a new window) by clicking the word mobile at the bottom of the page. Accessing it with your smartphone should use the mobile theme automatically. I'll center up the text after we've tested it out a bit and are sure it's working ok.
MCA 55330 | 69 Mach1 | 427 Stroker | 29 Model A Murray Town Car | 4 Banger
Offline Sluggo
  • Dark Overlord
Re: New theme and modification installed
« Reply #1 on: March 04, 2011, 08:42:31 PM »
Clicking on the mobile theme takes you to the mobile theme. Once in the mobile theme, there is a link at the bottom "go to full site" which open the full site in a new window.
This is meant as a correction to the above post where it says the mobile will open in a new window.
The mobile version loses a bit a functionality, so you only use it on your mobile device.
If you click the full site option from your device, it will display as full site until you choose mobile again. It should default to mobile unless you change it to full site.
As of this moment you know everything I know.
« Last Edit: March 04, 2011, 08:46:05 PM by Sluggo »
« Reply #2 on: March 04, 2011, 10:58:11 PM »
Just tried it on my iPhone, looks cool, thanks Randy!
