Author Topic: rubber filler hose and fuel sender wiring  (Read 529 times)
Offline k-code
« on: January 11, 2022, 06:31:53 PM »
Late 64 Dearborn coupe, rubber filler hose, is it cloth covered?
And where can I obtain the correct fuel sender wire including pigtail. I've tried the usual sources and no-one seems to stock it. CJ stock the cloth covering but their replacement pigtail isn't correct.
Andy
65 K code coupe, Dearborn, Dec 18, '64
Re: rubber filler hose and fuel sender wiring
« Reply #1 on: January 11, 2022, 08:36:17 PM »
Try Rhode Island Wiring http://www.riwire.com/
I got the insulation for my license plate wire there.
« Reply #2 on: January 11, 2022, 10:33:04 PM »
Filler hose should not be cloth covered.  Textured rubber.
https://www.wiringdepot.com/store/c/115-Asphalt-Coated-Loom.aspx
Offline k-code
« Reply #3 on: January 12, 2022, 01:25:20 AM »
So definitely not this one?
Andy
« Reply #4 on: January 12, 2022, 02:27:37 AM »
Definitely not.  I have had NOS ones with that service number and they were all regular rubber like I have seen on hundreds of cars.  It wasn't smooth rubber, a bit of a bumpy texture to it and usually had a white stripe.
« Reply #5 on: January 12, 2022, 04:54:23 PM »
Fair number of threads some with pictures of the filler tube. As far as we know - same as other plants of the time period
