Author Topic: Autolite 4100 HiPo Carburetor Part Question?  (Read 1130 times)
Offline Morsel
« on: January 09, 2022, 11:22:34 PM »
I'm wondering what the name of this brass flathead plug screw is called (see attached image)? If I knew the name of it, I would probably have an easier time searching for a new one, but if anyone knows a source let me know, need one for my carburetor.
Thanks as always,
Jason
Re: Autolite 4100 HiPo Carburetor Part Question?
« Reply #1 on: January 10, 2022, 12:27:25 AM »
It's a "plug", possibly including "vacuum advance" in it's description. What are the numbers/letters on the left front mounting foot?
Jimi
Offline Morsel
« Reply #2 on: January 10, 2022, 01:42:40 AM »
Jimi
Hey Jim,
It?s a 6Z F carb for my 66 HiPo automatic car.
Jason
Offline Dan Case
« Reply #3 on: January 10, 2022, 11:06:36 AM »
What did Ford call the plug? I have no idea. It seals the spark advance vacuum port that is not required for engines with fully mechanical ignition advance designs. (It is very different than the 1963-64 part used in carburetors for 427 and HP289 engines.) I spent most of a day digging through Ford parts books and training manuals one day in 2019 and never found an exploded view drawing or parts list line item for it in the 1964.5-67 production years. (I never found a Ford number of any kind for the 1963-64 version either.)
I made these drawings for somebody wanting to have some accurate copies made.
I have seen modern commercial replacements for sale but they lack the fine details of the unmolested originals I got to borrow and use for measurement work.
The flat faced straight threaded tapered seat for sealing plug went into use near the end of C3OF-AJ carburetor production in 1964 and was in April 1964 in C4OF-AL carburetors. The earliest carburetor assembly date code I have recorded using the flat face SAE thread plug is the last week of January 1964.
« Last Edit: March 08, 2023, 06:49:09 PM by Dan Case »
Dan
Offline Dan Case
« Reply #4 on: January 10, 2022, 11:34:22 AM »
The brass pipe thread part was a Ford-Holley piece for several street and race 427 Ford carburetors before September 1964. Circa September 1964 Holley changed to a zinc plated steel version for 427 Ford carburetors that used a plug and the R-3259/3259-1 carburetors for Shelby.  When the C3OF-AB carburetor was introduced with 289 High Performance engines in March 1963 they also used the brass pipe threaded part. The use of C3OF-AB carburetors ended circa Mid may 1963 and C3OF-AJ carburetors were used until at least mid May 1964.
« Last Edit: March 08, 2023, 07:04:40 PM by Dan Case »
Dan
Offline Morsel
« Reply #5 on: January 10, 2022, 01:23:55 PM »
The brass pipe thread part was a Ford-Holley piece for several street and race 427 Ford carburetors before September 1964. Circa September 1964 Holley changed to a zinc plated steel version for 427 Ford carburetors that used a plug and the R-3259/3259-1 carburetors for Shelby.  When the C3OF-AB carburetor was introduced with 289 High Performance engines in March 1963 they also used the brass pipe threaded part. The use of C3OF-AB carburetors ended circa Mid may 1963 and C3OF-AJ carburetors were used until at least late May 1964.
Thanks for the info Dan, very helpful and yeah, can't seem to find them anywhere online. Luckily someone had a couple and is sending me one, so at least I got one coming for my carb :)
Jason
Offline Dan Case
« Reply #6 on: January 10, 2022, 05:59:57 PM »
Jason
You are welcome.
Dan
