Author Topic: Engine mount brackets and insulator finish  (Read 425 times)
Offline 69 black r code
« on: January 09, 2022, 02:15:12 AM »
4-69 NJ 428cj
After doing a search I have found that the engine mount block bracket and frame bracket should be natural steel. Should the rubber insulator bracket be natural as well?
4-69 Mach1 NJ 428cj
Re: Engine mount brackets and insulator finish
« Reply #1 on: January 09, 2022, 11:50:38 AM »
4-69 NJ 428cj
It could be but more typically the upper portion was blacked out with the rubber coating or paint and the lower "ears" portion that the single motor mount bolt goes through was bare steel.
« Reply #2 on: January 09, 2022, 01:37:36 PM »
Thank You Bob. that's what I needed.
4-69 Mach1 NJ 428cj
