Author Topic: 68 floor console  (Read 751 times)
Offline TLea
68 floor console
« on: December 29, 2021, 03:55:00 PM »
New to me doing a Mustang center console. The opening for the shifter is longer than the chrome floating ring on the shifter boot. Is that normal?
Re: 68 floor console
« Reply #1 on: December 29, 2021, 05:38:34 PM »
On a mustang console with manual trans, the floating chrome bezel wasn't used.
« Reply #2 on: December 29, 2021, 06:05:26 PM »
+1 Based on what I'm seeing on the small number of unrestored I have pictures of with those two options
The Shelby difference likely influenced you in this matter
Couple of 67 manual bezel pictures that were handy. Real crumb and dust collector  ::)
« Last Edit: December 29, 2021, 06:13:15 PM by J_Speegle »
« Reply #3 on: December 29, 2021, 07:12:59 PM »
None from a great example or with the console removed but shifter and boot still in place like I hoped for but 68 examples with a peek into the installation. Could not let only 67 examples be posted
« Reply #4 on: December 30, 2021, 01:59:21 AM »
This is one of those cases where the carpet hole needs to be kept small so it fits tightly around the base of the rubber shift boot.
« Reply #5 on: December 30, 2021, 05:35:27 AM »
One good detail shown in the upper left corner of the 67 examples
Offline TLea
« Reply #6 on: December 30, 2021, 11:51:43 AM »
It weird as it shows chrome ring in assembly manual but we know how accurate those are (n't)
2 more questions
On the 68 version is the pebbly part of the console insert supposed to be black? Seeing black and chrome but neither verified original
In the assembly manual it shows a C8ZB 65045E18 AW trim that goes where the lower base contacts the dash. I can't find anything under a google search. In assembly manual pic it appears to be small u shaped gasket similar to seals used on quarter panel/headlight extensions?
« Reply #7 on: December 30, 2021, 12:18:51 PM »
Yep, pebble part should be black, more on the satin side (low sheen).
The trim pieces look like pinch on windlace, except one end is molded closed.  They are kind of hard to find.
Offline TLea
« Reply #8 on: December 30, 2021, 03:49:40 PM »
I'm assuming the end facing driver is closed? Is it typical windlace?
« Reply #9 on: December 30, 2021, 03:51:00 PM »
Yes, it's at an angle with the edge of the console end.  I think regular windlace could be used and maybe silicone one end smooth.  Dye it afterward so the silicone doesn't stand out.
Here's some pics of a pair currently on ebay...
« Last Edit: December 30, 2021, 03:59:56 PM by CharlesTurner »
« Reply #10 on: December 30, 2021, 03:59:05 PM »
Do you think that removing some of the metal "supports" or staple looking reinforcements would help accomplish that?
Offline TLea
« Reply #11 on: December 30, 2021, 04:02:43 PM »
Omigosh compared to most things we have to make those are easy lol
thanks gents
Offline TLea
« Reply #12 on: December 30, 2021, 04:22:19 PM »
There are little slots in the base that those closed ends snap in
