Author Topic: Seat belt warning light  (Read 848 times)
Offline Azdriver
« on: December 27, 2021, 06:38:48 PM »
Complete seat belt waring light including door jamb button. $125 plus $10 shipping in continental US.
From what I found, 1966 dealer installed option? Relay is actually a timer that shuts the light off after a short period....Button plunger in picture is not part of it....
Thanks, Pat
« Last Edit: March 12, 2022, 07:30:22 PM by Azdriver »
69 Mach 1 R code
66 GT coupe
68 GT500
Re: Seat belt warning light
« Reply #1 on: December 27, 2021, 09:19:51 PM »
What year is this from?
Offline Azdriver
« Reply #2 on: December 28, 2021, 01:14:36 AM »
Going by the numbers on the wiring it must be 66. Harness says C6ZB-14A31xxx numbers are missing.
« Last Edit: December 28, 2021, 01:24:29 AM by Azdriver »
69 Mach 1 R code
66 GT coupe
68 GT500
Online 196667Bob
« Reply #3 on: December 28, 2021, 12:51:19 PM »
For 1966, the Seat Belt Warning Light was not available as an Accessory, but came only with the Deluxe Seat Belt Factory Option. No "door jamb button" was part of the Option. This same thing is true for 1967 ; the Seat Belt Warning Light only came with the DeLuxe Seat Belt Factory Option.
See attached.
Bob
MCA 04909
Offline Azdriver
« Reply #4 on: December 28, 2021, 01:01:18 PM »
Thanks for the info...
Pat
69 Mach 1 R code
66 GT coupe
68 GT500
« Reply #5 on: December 28, 2021, 02:27:51 PM »
Here's a sketch i made in 2009 to punch the indicator light hole. I recommend a GREENLEE number 730, 3/4 inch chassis punch (an e-bay item).
Offline K-HESS
« Reply #6 on: December 28, 2021, 02:31:20 PM »
The pink wire with the button looks more like a glove box light. It will most likely have a spot on the end of the black plastic for a bulb.
« Reply #7 on: December 28, 2021, 04:10:36 PM »
True.
Also, the triple connector and it's associated wiring does not belong to the warning light harness itself. It's part of the installation. The yellow insulated wire with the male pin that goes into the triple connector is part of the warning light harness.
Offline Azdriver
« Reply #8 on: March 12, 2022, 07:30:42 PM »
Update
69 Mach 1 R code
66 GT coupe
68 GT500
« Reply #9 on: March 12, 2022, 09:33:39 PM »
Totally agree. Unrelated.
